Boost Pressure for Audi 100 AAT Turbo
Markus H.
Post13-10-2002, 0:09    Subject: Boost Pressure for Audi 100 AAT Turbo Quote
I would like to know what the maximum boost pressure is for the AAT engine (Audi 100, model C4, 5-cylinder, 115 hp) in its standard configuration.
I would be satisfied with just the maximum pressure and approximate speed at which it needs to stop.
'I doubt anyone has a complete diagram covering the entire speed range, do you think?'
I actually have a boost pressure gauge lying around here that I've been meaning to connect, so reference values would be helpful.
Translated on 05-09-2026, 7:33.
Michael II
Post13-10-2002, 11:56    Subject: Boost Pressure for Audi 100 AAT Turbo Quote
At approximately 3000 RPM and full throttle, the absolute pressure should be between 1.72 bar and 1.92 bar.
Tschüss
Michael II
Translated on 05-09-2026, 7:34.
christians
Post13-10-2002, 13:55    Subject: Boost Pressure for Audi 100 AAT Turbo Quote
Are these the target values or the values from your car? My AAT (turbocharger) only produces about 1 bar of boost, which it reaches at full throttle from 2200 RPM. Without electronic boost control (with the connector unplugged from the valve), it was a maximum of 0.6 bar.
Translated on 05-09-2026, 7:35.
Michael II
Post13-10-2002, 14:06    Subject: Boost Pressure for Audi 100 AAT Turbo Quote
These are the target values, ABSOLUTELY, meaning they are measured with ambient pressure. Your values (0.6 to 0.9) are relative.
Tschüss
Michael II
christians
Post13-10-2002, 14:23    Subject: Boost Pressure: Audi 100 AAT Troubleshooting Quote
Sorry, I didn't look closely enough.
Christian.
Translated on 05-09-2026, 7:36.
Markus H.
Post13-10-2002, 14:46    Subject: SEO: Best German to English Translation Services Quote
Okay, that's already been helpful.
Now for the question that nobody wants to hear:
Where do I connect the hose for the boost pressure gauge on the AAT (air intake manifold) in the Audi 100 (engine side)?
Attached to the intake manifold (where it says 'Turbo DI-Diesel') is a hose, about the thickness of a finger, that runs towards the back. Is that the pressure hose that leads to the engine control unit?
It was similar with the 1Z, at least in some respects.
Translated on 05-09-2026, 7:37.
christians
Post13-10-2002, 14:59    Subject: Boost Pressure: Audi 100 AAT Troubleshooting Quote
The easiest way is as follows: The hose leads to the pressure sensor, which, in the case of the AAT, is located on the injection rail together with various valves and connectors under a "aesthetically pleasing" plastic cover.
Translated on 05-09-2026, 7:38.
Markus H.
Post13-10-2002, 16:23    Subject: SEO: Best Practices for Website Optimization Quote
Thanks, that was incredibly fast again!
@christians:
Yes, this hood, finished in a sophisticated black and made of high-quality plastic, is indeed striking in its beauty and serves as an eye-catcher in the otherwise barren engine compartment. Opening the hood will be a pleasure for years to come! *ahem* icon_wink.gif
It was probably a somewhat misplaced precursor to the engine covers that are now commonly found everywhere, designed to prevent people from noticing leaks or other issues.
Oh, by the way, speaking of the engine compartment,
I just remembered something else (even though it's annoying):
Is it actually difficult to retrofit this engine bay lighting, which was probably available as an option?
There's already space for a lamp in the insulation pad under the hood. I'm just wondering if the cables are already in place?
(I don't have much time to remove the insulation pad right now).
Translated on 05-09-2026, 7:39.
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 2.5 TDI: Boost Issues When Downshifting. Diesel Engine Technology
No new posts max. Boost pressure for the 115 PD AUY Diesel Engine Technology
No new posts Only 0.5 bar of boost pressure at idle Diesel Engine Technology
No new posts High loading pressure? - Audi A4 1.9 TDI, manufactured in... Upload
