Workshop action: Incorrect coding on VW Golf/Passat (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post14-10-2002, 11:19    Subject: Workshop action: Incorrect coding on VW Golf/Passat Quote
Golf IV / Passat B5 with extended service interval (ESI), part number QG1.
Activating extended maintenance interval.
Affected vehicle identification numbers (VINs):
From WVW ZZZ 1JZ YP 161 129 to WVW ZZZ 1JZ YP 161 459.
WVW ZZZ 3BZ YP 093 434 to WVW ZZZ 3BZ YP 096 726.
Cause:
Vehicles with extended maintenance intervals (EMI) within the affected vehicle identification number (VIN) ranges may have a situation where the extended maintenance interval function was not activated due to a programming error. This means that the corresponding maintenance intervals are not flexible but are determined and displayed statically.
Procedure:
The encoding for the instrument cluster should be:
XXX1X (a five-digit coding number where "1" indicates a flexible interval). If a "0" is entered in this field, the control unit must be re-coded. In this case, only the "0" (the fourth digit in the code) should be changed to a "1".
Example: The code number "34502" should be changed to "34512".
Adjusting adaptation channels (no login required).
Channel 43: Target value 00030.
Channel 44: Target value 00730.
Channel 45: Setpoint 00002.
Important:
A written customer notification is not planned.
Tschüss
Michael II
Translated on 22-07-2026, 0:07.
Ratings - Workshop action: Incorrect coding on VW Golf/Passat
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat B5: Tensioner Mounting Nut Workshop Deal Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B: Power Steering Repair & Service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 8E Recall: Action 75 B2 Fix Transmission, Chassis, Body & Interior
No new posts Injektorengröße Golf 7 und Passat B8 Diesel Engine Technology
No new posts Klimakasten Vergleich: Golf IV vs. Passat 35i: What is... Transmission, Chassis, Body & Interior
No new posts 1Z Steuergerät vom Passat 35i an Golf 3 betreiben? On-Board Diagnostics (OBD)
