ZV Coding: Unlock Trunk?
Julian
Post09-07-2005, 15:37    Subject: ZV Coding: Unlock Trunk? Quote
Hello!
On my central locking system (ZVL) for my Audi A4 8E (2003), I have the option, through coding, to automatically lock the doors starting at 15 km/h, and...
+000016 - Hedge unlocking disabled above 5 km/h
..to activate.
The +000016 can also be coded into TCU 46 without any issues, but I don't notice any effect.
The trunk can be opened even when the car is moving at speeds above 5 km/h, as can the rear doors, both from the inside and outside.
Does anyone have a tip as to what this could mean?
P.S.: The rear lid release via a button inside the vehicle does not exist, and the one via the FFB (remote key) also doesn't work if the key is in the ignition. If that's what was meant... icon_question.gif
Translated on 23-10-2026, 1:25.
vagtuning
Post09-07-2005, 16:46    Subject: ZV Coding: Unlock Trunk? Quote
How did you test that?
Start the engine, then it will lock.
Hold on, he's still there.
As soon as you open the driver's door, it unlocks... or when you remove the key.
The doors lock when you add +32 to it!
It's quite obvious that the doors always open from the inside unless the child safety lock is engaged! And definitely, they no longer open from the outside with the auto-lock feature enabled!
Translated on 23-10-2026, 1:27.
Julian
Post10-07-2005, 8:44    Subject: ZV Coding: Unlock Trunk? Quote
Hi!
Tested with a person weighing over 2nd weight class. > 5 km/h is easily achieved.
Whether it's +32, icon_smile_thumb_up.gif6, or +48 degrees (Celsius), the trunk lid only locks when I press the central locking button on the door again.
And, to be honest, it's a bit silly if all 4 doors are locked, but the trunk remains unlocked. icon_confused.gif
Translated on 23-10-2026, 1:28.
vagtuning
Post10-07-2005, 9:01    Subject: ZV Coding: Unlock Trunk? Quote
What coding is currently set in the car?
Translated on 23-10-2026, 1:29.
Julian
Post10-07-2005, 9:22    Subject: ZV Coding: Unlock Trunk? Quote
Hi!
06720
Okay: 06768.
vagtuning
Post10-07-2005, 9:32    Subject: ZV Coding: Unlock Trunk? Quote
Hmmm, if it's not an Avant model, then the coding is actually 100% correct.
If it really can't be done any other way, maybe the control unit is just malfunctioning.
What is the part number for the comfort control unit, according to the diagnosis?
Julian
Post10-07-2005, 9:39    Subject: ZV Coding: Unlock Trunk? Quote
8E0 959 433 AS
Comfort device T01 1210.
It's a soda, but it really shouldn't matter, because the motor in the tailgate always performs the same functions. icon_smile.gif
Translated on 23-10-2026, 1:30.
vagtuning
Post10-07-2005, 9:42    Subject: ZV Coding: Unlock Trunk? Quote
Please wait until next week!
433 AS... I think I know the cause, but let me check it first.
Translated on 23-10-2026, 1:31.
Julian
Post10-07-2005, 9:48    Subject: ZV Coding: Unlock Trunk? Quote
Julian
Post17-07-2005, 20:28    Subject: ZV Coding: Unlock Trunk? Quote
433 AS... I think I know the cause... but let me check that first.
vagtuning
Post20-07-2005, 18:41    Subject: ZV Coding: Unlock Trunk? Quote
Sorry, I had a bit of a time crunch.
Unfortunately, it affected the Bxx series, so it didn't affect yours.
Translated on 23-10-2026, 1:32.
Julian
Post20-07-2005, 19:21    Subject: ZV Coding: Unlock Trunk? Quote
Hi!
What was this sequence about? Did this encoding not work?
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
No new posts STG Coding: Explained & How-To Guide Diesel Engine Technology
No new posts MSG AKN Coding: Guide & Explanation On-Board Diagnostics (OBD)
No new posts PLC Programming: Your Guide to STG Coding On-Board Diagnostics (OBD)
