Lift Kit: Raise Your Vehicle's Height
edgar-s
Post27-04-2005, 11:03    Subject: Lift Kit: Raise Your Vehicle's Height Quote
Hello, I often drive on gravel roads during my vacations. Is there a simple way to raise the car's ride height?
Translated on 01-10-2026, 16:42.
Post27-04-2005, 16:15    Subject: Lift Kit: Raise Your Vehicle's Height Quote
YES, Bilstein B4 shock absorbers icon_smile.gif.
This is not entirely meant seriously, but my G3 is noticeably higher icon_evil.gif since the original shock absorbers were replaced with B4 gas shock absorbers (which are essentially the same as the original ones).
Troubleshooter
Post28-04-2005, 8:43    Subject: Lift Kit: Raise Your Vehicle's Height Quote
Hey guys,
If it's a GIV, there's an off-road suspension that raises the body by about 3-4 cm. However, it looks absolutely terrible. icon_biggrin.gif
Best,
Greetings,
Cheers,
Warmly,
Sincerely,
Best wishes,
Kind regards,
All the best,
Take care,
Love,
XOXO,
Hugs,
See you soon,
Talk soon,
Looking forward to hearing from you,
Hope this finds you well,
Have a great day,
Have a nice weekend,
Best,
Translated on 01-10-2026, 16:43.
Blechmann
Post19-07-2005, 13:06    Subject: Lift Kit: Raise Your Vehicle's Height Quote
Hi!
Okay, I once had a Golf 2 Syncro with 90 horsepower and an automatic transmission, and I modified it like this:
1. All interior components, from the rear.
2. Side windows, welded shut with sheet metal.
Rear complete suspension legs from a Passat 32b Syncro, specifically the off-road suspension version, designed for increased load capacity.
4. Complete front shock absorbers from a Passat 35i TDI.
5. The rear differential lock can be manually engaged (otherwise, it engages automatically when reversing).
Result:
Ground clearance of 35cm under the sills and extreme off-road capability!
and I really tried it out extensively... some Jeep drivers couldn't believe their eyes. icon_twisted.gif
Of course, this car has never been to a technical inspection (TÜV) or a traffic control (thankfully for me!). icon_wink.gif
Translated on 01-10-2026, 16:45.
datsun
Post22-07-2005, 7:40    Subject: Lift Kit: Raise Your Vehicle's Height Quote
Hello Edgar,
For the rear, there are additional springs that can be easily installed inside the normal springs.
You can find these on camper vans or in vehicles converted to run on gas. I have a price of around 150 Deutschmarks in mind. I don't know how it works with the TÜV (German technical inspection). But it looks quite original.
Good luck.
Rainer.
Translated on 01-10-2026, 16:46.
goettmann
Post22-07-2005, 17:20    Subject: Lift Kit: Raise Your Vehicle's Height Quote
You can find them when traveling in caravans or when converting cars to run on gas.
MAD auxiliary feathers:
http://www.hrbanhaenger.ch/sortiment_get.php?marke=mad
TÜV is okay! / TÜV is done! / TÜV passed!
Translated on 01-10-2026, 16:47.
Martin L.
Post28-07-2005, 14:37    Subject: Lift Kit: Raise Your Vehicle's Height Quote
Alternatively, you can find rings in the DTS catalog that are designed to be placed between the spring and the spring seat. These rings have a V-shaped profile on both sides. They allow you to increase the ride height without making the suspension excessively stiff, and they also help to maintain the overall suspension tuning.
Translated on 01-10-2026, 16:48.
No new posts Car Vacation Checklist: Essential Vehicle Prep General Tips
No new posts Document: MKB AKF, Vehicle vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, horn honks by itself Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install AHF in AFN Vehicle? Diesel Engine Technology
This topic is locked, you cannot edit or reply. Lifting the vehicle Transmission, Chassis, Body & Interior
No new posts Vehicle measurement Transmission, Chassis, Body & Interior
No new posts Vehicle Diagnostics Protection: What is SFD? On-Board Diagnostics (OBD)
