mansab Guest
28-07-2005, 12:50 Subject: Trailer |
How can I activate the trailer indicator light control? (Applicable to VW T5 and other vehicles like the Seat Ibiza, etc.)
Thank you very much, Manfred.
Translated on 04-07-2026, 20:41.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
28-07-2005, 15:40 Subject: Trailer |
Hello Manfred,
Is the coding in the body control module (address 09) adjusted?
Bit 1 (weight: 2) must be set.
Translated on 04-07-2026, 20:42.
Profile PM WWW Garage |
mansab Guest
29-07-2005, 17:33 Subject: Trailer |
Thank you for the quick response.
'What is the value of bit 1?'
Manfred
29-07-2005, 21:36 Subject: Trailer |
Bit 1 of the value indicates whether or not the vehicle has a trailer hitch.
Example: Trailer hitch disabled; the old value is encoded as 17 (this is an arbitrarily chosen value; read yours and write it down!).
17 = 16 (Bit 4) + 1 (Bit 0) = binary 10001.
The binary representation 10011 corresponds to the decimal value 19.
Translated on 04-07-2026, 20:43.
29-07-2005, 23:04 Subject: Trailer |
To cut to the chase...
For the T5, Rainer is correct; simply add 2 to the current encoding.
However, with the Ibiza, it's different; there, it's 1 (bit 0).
Translated on 04-07-2026, 20:44.
