prototyp80 Blaumann
Joined: 06/29/2005 Posts: 35 Karma: +2 / -0 Location: CH- Galgenen
04-08-2005, 8:37 Subject: VAG-COM: Strange Values on Audi A4 (1995) |
I'm having a problem reading and logging data from the mass airflow sensor (MAF) in a 1995 Audi A4 1.8L ADR.
If a measurement value (MWB) is labeled with "speed," for example, it is possible that the value is given in g/s and does not correspond to the actual speed  . In another MWB, the mass flow rate (LMM) might be indicated with "ms," etc.
Is VAG-COM too new for this vehicle, or is the vehicle too old for VAG-COM? Or do I have a problem with the software or hardware, or is the issue related to the vehicle's control unit?
Thank you for your help.
Sebastian. Passat Variant 1.9 TDI (AVF) 2WD Modell 2005
Citroen C3 1.6 16V HDi Bj 2007
Translated on 31-08-2026, 15:57.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
04-08-2005, 9:17 Subject: VAG-COM: Strange Values on Audi A4 (1995) |
Hi Sebastian,
Could you please provide the complete VAG part number of your control unit?
Reason: Using the VAG part number, VAG-COM searches for a suitable label file for your control unit. This file, among other things, defines the names of the fields in the measurement blocks (it is a text file).
If a label file is not found, VAG-COM attempts to guess the type of the values, which can of course lead to errors.
Translated on 31-08-2026, 15:59.
Profile PM WWW Garage |
prototyp80 Blaumann
04-08-2005, 9:46 Subject: VAG-COM: Strange Values on Audi A4 (1995) |
Hi Rainer,
I don't have the number readily available  ; I'll have to check again after work.
Denke mit der Fahrgestellnummer kannst Du nichts Anfangen?! I would have...
Translated on 31-08-2026, 16:00.
04-08-2005, 10:06 Subject: VAG-COM: Strange Values on Audi A4 (1995) |
No, the chassis number doesn't help  . The VAG part number of the respective control unit is displayed directly in the first screen on the left side in VAG-COM when you access the control unit.
Translated on 31-08-2026, 16:01.
prototyp80 Blaumann
04-08-2005, 20:35 Subject: VAG-COM: Strange Values on Audi A4 (1995) |
Hello Rainer,
Okay, I now have the number of the control unit.
8D0 907 557 CX
04-08-2005, 21:35 Subject: VAG-COM: Strange Values on Audi A4 (1995) |
is the content of.
[Edit]
dead link
[Edit]
plausible?
If yes, save the file as 8D0-907-557-CX.lbl in the 'Label' directory.
Translated on 31-08-2026, 16:02.
prototyp80 Blaumann
05-08-2005, 6:20 Subject: VAG-COM: Strange Values on Audi A4 (1995) |
Hello Rainer,
Thank you for the link!
It's good that we'll have the weekend soon, then I can check that.
Translated on 31-08-2026, 16:03.
05-08-2005, 6:50 Subject: VAG-COM: Strange Values on Audi A4 (1995) |
You can also try searching on Google (e.g., next week).
Search for 8D0-907-557-ADR.lbl
05-08-2005, 11:25 Subject: VAG-COM: Strange Values on Audi A4 (1995) |
Rainer K. wrote: | | http://www.ross-tech.com/vag-com/download/label-files/8D0-907-557-C.lbl |
Am I too stupid, or is the link not working?!
Rainer K. wrote: | You can also try searching on Google (e.g., next week) for...
Search for 8D0-907-557-ADR.lbl  |
Currently, no results, but why then next week?!
Translated on 31-08-2026, 16:04.
05-08-2005, 11:46 Subject: VAG-COM: Strange Values on Audi A4 (1995) |
Besswerwisser wrote: | Rainer K. wrote: | | http://www.ross-tech.com/vag-com/download/label-files/8D0-907-557-C.lbl |
Currently, no results, but why then next week?!  |
Hi Sebastian S.,
You don't need to post anonymously to draw attention to files that were requested and created on August 3, 2005. Especially if you consider time zones...
Okay: Sebastian S. has updated the link at Ross-Tech and added some files.
http://www.ross-tech.com/vag-com/download/label-files/8D0-907-557-ADR.lbl
Either save the file using your VAG part number, or copy the entire directory to your label directory (make sure to back up and empty the directory first).
Since the .zip file is from April, the easiest way is to use 'wget' or a similar tool.
Translated on 31-08-2026, 16:05.
05-08-2005, 13:12 Subject: VAG-COM: Strange Values on Audi A4 (1995) |
http://www.ross-tech.com/vag-com/download/label-files/8D-01.lbl
...then, if appropriate, one should also suggest that he use the corresponding redirect...
...then he can save himself the trouble of renaming it... (provided that VAG-COM 405.0 or higher is available).
Rainer K. wrote: | | You don't have to post anonymously... |
I don't think I was wanted in a different way... but we can talk about that privately, or not at all...
Translated on 31-08-2026, 16:07.
05-08-2005, 13:54 Subject: VAG-COM: Strange Values on Audi A4 (1995) |
Besswerwisser wrote: | http://www.ross-tech.com/vag-com/download/label-files/8D-01.lbl
...then he can save himself the trouble of renaming it... (provided VAG-COM 405.0 or higher is available).  |
Yes, but then he should update everything, so the entire label directory. It's just more work, and eventually, there will be another update from me where I'll repackage the installation.
Translated on 31-08-2026, 16:08.
05-08-2005, 14:10 Subject: VAG-COM: Strange Values on Audi A4 (1995) |
Translated on 31-08-2026, 16:09.
05-08-2005, 14:30 Subject: VAG-COM: Strange Values on Audi A4 (1995) |
Thank you, that saves time.
prototyp80 Blaumann
08-08-2005, 11:28 Subject: VAG-COM: Strange Values on Audi A4 (1995) |
It's nice that you're so concerned about my label files!
I now have the link. Do I need to save the old labels, delete them, and then save the new ones?
By the way, I have VAG-COM 504.1, so it shouldn't cause any problems!
Thank you for your efforts  .
Translated on 31-08-2026, 16:10.
08-08-2005, 12:18 Subject: VAG-COM: Strange Values on Audi A4 (1995) |
There are several ways to handle this, but the simplest would probably be to rename the existing label directory and use the zip file as the new 'label' directory.
Translated on 31-08-2026, 16:11.
