Chip Shortage: Boxed Products Affected?
Switch
Post02-05-2002, 9:17    Subject: Chip Shortage: Boxed Products Affected? Quote
Hey everyone...
Okay, here's the translation:
'I have a question. I have a chip installed in my Golf TDI, but it's really bad (causing smoke, etc.). Yesterday, we installed a 'black box' in addition to the chip. You know, that kind of device that you put in between the fuel injection system. Now my question is: Does this device actually do anything? I haven't noticed any difference. Is it bad for the engine control unit (ECU), since there are now two performance enhancements installed? A friend of mine said that it's possible that having both a chip and a box could potentially damage the ECU.'
Thank you in advance...
Translated on 22-09-2026, 11:30.
Jan6K
Avatar-Jan6K
Post02-05-2002, 9:37    Subject: No Addition: Simple Recipes for Healthy Eating Quote
Performance improvements do not add up!
If in doubt, the module may corrupt the signals to such an extent that the control unit can no longer process them correctly. This is especially true because it's not running the original software, but rather the tuning software of the chip. And all of that together just leads to problems...
... OR...
... it sprays for so long that it will eventually melt the pistons!
I would leave that alone!
Each tuning part starts from a "normal state," and that normal state doesn't actually exist. Therefore, the device isn't running in the environment it was designed for, and neither is the chip.
Jan.
1Z5 CFHF / AHB H4D
Translated on 22-09-2026, 11:32.
Post02-05-2002, 15:38    Subject: Rename Topic: How to Change Topic Title Quote
Hi Switch.
I've taken the liberty of renaming your topic. The original title "Electricals" seemed too broad, as it could have also included things like batteries, starters, connectors, etc.
No offense icon_smile.gif.
By the way, you generally can't break the control unit itself; at most, you can push it to the point of desperation, causing it to go into emergency mode and send out an SOS signal via the glow plug indicator.
Translated on 22-09-2026, 11:33.
JET
Post02-05-2002, 17:15    Subject: Chip Shortage: Boxed Products Affected? Quote
Hello, the chip and the box cannot be used together; you must choose one. Personally, I prefer a chip. If you are not satisfied with the chip, try one from a different tuner. However, if you want to use the box, you will need to reinstall the original software in the control unit.
Translated on 22-09-2026, 11:34.
Stefan
Post03-05-2002, 7:20    Subject: Chip Shortage: Boxed Products Affected? Quote
Which tuning company makes your chip?
'chip & box' don't go together.
Mostly, it's like this: if your engine is already making noise...
And if you give him even more fuel now, he won't become less aggressive! It will only amplify his negative traits.
It's better to take the box out. You risk a major engine failure!!
Translated on 22-09-2026, 11:35.
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Chip Tuning 115 PS - Performance Upgrade Diesel Engine Technology
No new posts AFN Chip: What it is and how it works On-Board Diagnostics (OBD)
No new posts TÜV and Chip: What You Need to Know Diesel Engine Technology
No new posts AFN Timing Belt & Chip Replacement Diesel Engine Technology
