Oil Service Data: Read Measurement Values
AudiS3
Post14-08-2005, 23:19    Subject: Oil Service Data: Read Measurement Values Quote
Hello!!
My brother has a Polo, model year 09/2004, chassis code 9N1. Can anyone tell me how to read the information about when the next oil change is due using VAG-COM?
For my Audi, I only need to press the left button in the Combi display. Unfortunately, his Polo doesn't have that button icon_sad.gif.
Thank you in advance for your help.
Translated on 20-10-2026, 2:34.
Post14-08-2005, 23:37    Subject: Oil Service Data: Read Measurement Values Quote
Just take the right button icon_wink.gif.
Turn on the ignition, press the button for 3 seconds, and be amazed icon_biggrin.gif.
Translated on 20-10-2026, 2:35.
AudiS3
Post15-08-2005, 14:54    Subject: Oil Service Data: Read Measurement Values Quote
Post15-08-2005, 15:20    Subject: Oil Service Data: Read Measurement Values Quote
It should be stored in the highest measurement value blocks within the engine control unit, but sometimes there are gaps before the relevant blocks.
Translated on 20-10-2026, 2:36.
Ross-Tech-Support
Post15-08-2005, 18:23    Subject: Oil Service Data: Read Measurement Values Quote
Roger wrote:
It should be stored in the highest measurement value blocks within the engine control unit, but sometimes there are gaps before the interesting blocks.
It definitely wouldn't be in the engine control unit, as that has nothing to do with the service interval data.
The keyword is "instrument cluster".
Code:
005,0,Serviceinformationen
005,1,Serviceüber-,schreitung,Strecke
005,2,Serviceüber-,schreitung,Zeit
005,3,Restlaufstrecke
005,4,Restlaufzeit
006,0,Serviceinformationen (Öl) [WI = Wartungsintervall]
006,1,Min. Ölstands-,abweichung
006,2,Max. Ölstands-,abweichung
006,3,Langzeit,Mittelwert,Ölstandsdifferenz über die letzten 100 km
006,4,Motorhauben-,kontakt,Wertebereich: Auf = Motorhaube geschlossen / Zu = Motorhaube geöffnet
007,1,Aktueller,Ölstand [mm],vom TOG-Sensor
Post15-08-2005, 18:37    Subject: Oil Service Data: Read Measurement Values Quote
The keyword is combination instrument...
Ouch, you're right icon_redface.gif.
Translated on 20-10-2026, 2:37.
AudiS3
Post15-08-2005, 23:36    Subject: Oil Service Data: Read Measurement Values Quote
ok, thanks!!
Okay, then address word 17 --> for combination.
then code 005, 006, etc...
I will definitely test it out tomorrow icon_exclaim.gif.
Ross-Tech-Support
Post16-08-2005, 0:14    Subject: Oil Service Data: Read Measurement Values Quote
No code.
VAG-COM > Select Control Unit > 17 - Instrument Cluster > 08 - Measuring Blocks.
You can then select the measurement groups.
Translated on 20-10-2026, 2:38.
No new posts T5 AXE: Data Logging & Measurement Block Diesel Engine Technology
No new posts Skoda Octavia: Reset Oil Service Light On-Board Diagnostics (OBD)
No new posts Read Email: Extracting Messages Easily On-Board Diagnostics (OBD)
No new posts Read CAN Bus with Microcontroller On-Board Diagnostics (OBD)
