ESP Light On, Engine Misfire - Get Help Now!
mishu
Karma: +0 / -2   Thank you, like it!
Post10-09-2005, 19:36    Subject: ESP Light On, Engine Misfire - Get Help Now! Quote
Hello everyone, I have a Passat 3BG, model year 2002, 1.9 TDI, 130 horsepower, automatic transmission.
For the past week, the car has been running erratically from time to time, and the ESP warning light has been coming on. I turn the car off and on again, and the error disappears. However, it reappears after a certain amount of time.
Könnnt ihr mir helfen?!? Thank you.
Error codes:
Address 1.
18074 Valve for pump/nozzle, cylinder 1 (N240), electrical fault in circuit P1666 - 35 - 10 --- Intermittent.
Address 2.
18265 - Last signal error message from the engine control unit.
P 1857 - 35 -10 - Interrupted.
Address 3.
Translated on 13-09-2026, 2:06.
Post10-09-2005, 19:54    Subject: ESP Light On, Engine Misfire - Get Help Now! Quote
For a week now, the car has been running erratically from time to time
It's no wonder that a PD (Partial Discharge) element occasionally doesn't get properly triggered from the motor because there's a loose connection in the circuit, right? icon_smile.gif
Carefully inspect the plugs and cables connected to the PD element.
The other two errors seem to indicate a lack of proper communication between the ESP (Electronic Stability Program), the automatic transmission, and the engine control unit.
Is the connector on the engine control unit properly connected and is the locking mechanism engaged?
Translated on 13-09-2026, 2:08.
mishu
Post10-09-2005, 20:08    Subject: PD Element: What is it? Quote
Where can I find the PD element?
Translated on 13-09-2026, 2:09.
Post10-09-2005, 22:14    Subject: ESP Light On, Engine Misfire - Get Help Now! Quote
Ouch, was that question meant to be taken seriously?
I would start by looking at the engine. Get a self-study program (SSP) for your engine:
https://erwin.volkswagen.de/erWinVW/docshopFlowControl.jsp?doAction=selectDocument&docid=18651
or simply do a Google search.
Post11-09-2005, 21:05    Subject: ESP Light On, Engine Misfire - Get Help Now! Quote
mishu wrote:
Today, I tinkered with the engine and measured the connection between the PD unit and the control unit. Everything was OK. After reassembling everything, the engine ran perfectly again. I hope it stays that way, otherwise I'll have to swap the PD units and see if the problem moves.
Best regards, Chris
Okay, but why a new topic? I copied the text here and deleted the individual post.
Translated on 13-09-2026, 2:10.
No new posts Error codes and their causes for MKB AJM, ATJ, AVF, AWX Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB AMF Error Codes: Causes and Effects Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error Codes, Causes and Effects for MKB ASZ, AXR, ATD Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Stalling, TCS Light On: Troubleshooting Guide Diesel Engine Technology
No new posts Engine Misfire: Troubleshooting & Error Codes On-Board Diagnostics (OBD)
No new posts BKD engine running rough Diesel Engine Technology
No new posts 1.9 TDI VP37 Engine Misfire After 20 Seconds Diesel Engine Technology
