Tank- und Temp.-Anzeige; nach Reparatur noch schlechter :-( | Posts 16+
Go to page: Previous  1, 2
Kanute
Post14-09-2005, 13:33    Subject: Quote
Mephisto wrote:
I'm just wondering where the workshop plans to get the TCA 700 Y from. As far as I know, it's no longer in production. I would have chosen the standard 08/15 78S10 model, which is also used in Audi combination instrument panels.
Micha
They are in the drawer. Some of them.
Thank you and best regards.
Florian.
94er VW Passat 35i 1Z 302.520 km
Der Wagen steht aktuell (23.1.2013) zum Verkauf, TÜV 1/2013
Back to top Profile PM Email
joegolf
Post14-09-2005, 16:35    Subject: Quote
Just remember that not all voltage regulators are compatible with each other. I'm not familiar with the TCA 700, so I can't say anything about it. Some (like the LM317, LT1086, etc.) just have the IN-GND-OUT pins arranged in a different order, GND-OUT-IN, just for fun...
However, the 2940 is pin-compatible with the 78xx series, with the IN-GND-OUT pinout.
Golf 7 GTI
Mephisto
Karma: +14 / -1   Thank you, like it!
joegolf likes this.
Post15-09-2005, 7:44    Subject: Quote
The LM317 is an adjustable voltage regulator. Pin 1 is not ground, it's adjust!
"Micha"
Kanute
Post15-09-2005, 10:07    Subject: Quote
Hi!
Thank you for your input and troubleshooting tips. Because I was running out of time, I had a new circuit board installed, and everything is working fine now. The fuel gauge seems accurate, the temperature gauge is rising, and the instrument lighting appears to be much brighter than before, at least that's my impression.
Florian.
chli1976
Post15-09-2005, 11:02    Subject: Quote
I also only replaced the voltage regulator once, on a Passat. I got it from an electronics store. However, the connectors on that type were different from the original. I ended up soldering it using thin wires to make it fit, and it works fine. "In addition, I soldered the cables directly to the 12V terminal 15 and connected the output to the temperature and fuel gauges using a separate cable (soldered)."
No new posts MKB ABC: Engine Start Issues After MSG Replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cushion button repair General Tips
No new posts Repair of oil pump drive for 2.0 PD TDIs with balance shafts Troubleshooting & Guides
No new posts Temperature Display: Check & Troubleshooting Diesel Engine Technology
No new posts Temperature Sensor Errors: Short Circuit to Ground Diesel Engine Technology
No new posts Car Door Repair: After Inspection On-Board Diagnostics (OBD)
No new posts AC Noisy After G65 Sensor Repair Transmission, Chassis, Body & Interior
