Incorrect calculation! | Posts 16+
Go to page: Previous  1, 2
Avatar-Jan6K
Post02-05-2002, 15:43    Subject: Incorrect calculation! Quote
Your invoice is still incorrect!
The peak power (85 KW at, e.g., 4000 RPM) and torque (285 at 1900) values are completely unrelated! Your correction value of 0.157 is therefore incorrect.
You need to take the performance at 1900 RPM, and you can find that by taking the point on your graph where the engine is running at 1900 RPM - you'll get an approximate value with a little trial and error - I'm guessing that in 5th gear, it should be around 90 km/h - but it might be different for your car. And with the performance, you can then calculate the torque at 1900 RPM.
Jan
1Z5 CFHF / AHB H4D
Post02-05-2002, 15:56    Subject: Calculation Formula: RPM / Nm / kW Quote
Hi zusammen
The correct formula is (described in a popular way):
kW = (Nm x rpm) / 9549
That means, the 81 kW TDI engine produces approximately 190 Nm at 4000 rpm, and around 47 kW at 1900 rpm with 235 Nm.
Uwe
Post03-05-2002, 17:36    Subject: Incorrect calculation! Quote
Hi!
Sorry, I mixed up * and /...
Best regards, Uwe
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Squeal: A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Clutch Slipping - 81kW Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Intercooler for A3 with AGR: Will it fit? Diesel Engine Technology
No new posts Does this control unit fit? On-Board Diagnostics (OBD)
No new posts AAT Cylinder Head: Fits 1T Engine Block? Diesel Engine Technology
No new posts Coupling Diesel Engine Technology
