Problems with gears 4 and 5.
windl
Post27-10-2002, 21:18    Subject: Problems with gears 4 and 5. Quote
My Golf IV AHF 110PS, 93000km, has recently been experiencing acceleration problems in 4th and 5th gear, starting from a speed of 3400 rpm. When full throttle is applied, the power is automatically briefly reduced for about 1 second, and then the car accelerates again. In 5th gear, it consistently loses power, making it very difficult to reach the maximum speed.
Is it possible that the LMM is defective, as has been often heard?
Thank you for your answers.
Greetings
Erwin
Alois
Post28-10-2002, 10:29    Subject: Problems with gears 4 and 5. Translating...
[Translating...]Ja, das hört sich nach LMM an. Da er relativ teuer ist (ca. 280€) würde ich ihn aber nicht auf Verdacht tauschen.
Vielleicht kennst du jemanden, der dir seinen LMM für eine Testfahrt leiht.
So habe ich es gemacht.
Uwe
Post28-10-2002, 12:04    Subject: Problems with gears 4 and 5. Translating...
[Translating...]
Hei!
Bei Deiner Werkstatt könntest Du auch Erfolg haben, die machen das oft, probehalber einen anderen LMM zu testen.
gruß Uwe
No new posts Document: Gear Noise, 6-Speed Transmission Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gearbox 02K: 3rd Gear Hard to Shift Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Polo 1.4l TDI BMS - Acceleration Problems On-Board Diagnostics (OBD)
No new posts Sharan/Alhambra/Galaxy(AFN) 5-Gang. Ändern 5.Gang? Diesel Engine Technology
No new posts Golf 5 1.9 TDI 5-speed 6-speed gearbox ZMS clutch Diesel Engine Technology
No new posts Speed signal at 6th gear is the same as 5th gear? Transmission, Chassis, Body & Interior
