Injection Molding: What Do These Values Mean?
Roadagain
Post07-11-2005, 20:10    Subject: Injection Molding: What Do These Values Mean? Quote
I have a Passat car manufactured in 1994 with a 1Z engine.
Using VAG-Com, I read the following values from measuring block 13:
Cylinder 1: 0.27 mg per dose.
Cylinder 2: 4.98 mg per injection.
Cylinder 3: 4.51 mg Hub.
Cylinder 4: ---
Attached should also be a Screenshot of it.
Am I correct in understanding that cylinders 2 and 3 are being injected with almost 5 mg more per injection than cylinders 1 and 4?
Or what exactly are these values telling me?
According to the target values, they are indeed concerning, aren't they?
Can I adjust something there, or is the pump broken?
The nozzles have only been used for about 15,000 kilometers.
Occasionally, the car produces a significant amount of smoke, but only for a short period. It also tends to stutter or jerk, especially when it's cold.
I would normally use the search function, but I have no idea what keywords to use, and when I tried searching for something else, I didn't find anything.
Please give me some hints.
Greetings.
 File size:  37.97 KB
 Viewed:  2125 times
Translated on 20-08-2026, 13:07.
rinderwahnsinn
Post07-11-2005, 20:31    Subject: Fuel Injection Values: What Do They Mean? Quote
Do they come from a truly reliable source?
Translated on 20-08-2026, 13:10.
Roadagain
Post07-11-2005, 20:32    Subject: Injection Molding: What Do These Values Mean? Quote
I purchased the injectors directly from Volkswagen as replacements.
Post07-11-2005, 21:58    Subject: Injection Molding: What Do These Values Mean? Quote
Perform a compression test.
P.S.: Are the nozzles already properly installed?
Translated on 20-08-2026, 13:11.
vagtuning
Post07-11-2005, 22:33    Subject: Injection Molding: What Do These Values Mean? Quote
Where is the boundary of the 1Z zone? Is it at +5 or -5?
With the newer models, do the values already reach their maximum at around 3.xx, or am I missing something?
Post07-11-2005, 23:13    Subject: Injection Molding: What Do These Values Mean? Quote
Theoretically, a misaligned engine mounting frame should also be able to cause meaningless values in the idle speed control system (I'll call it "idle speed regulation").
Assuming the MSW (Motor Speed Wheel) is being difficult and not cooperating with the EDC's (Electronic Damping Control) attempts to quickly compensate for imbalances, then the "imbalance" persists, and the EDC has to try harder to correct it, which means setting increasingly higher values in the LLRR (likely referring to a control parameter).
She would do that even if the compression and nozzles are in perfect condition.
The LLR (Longitudinal Load Range) settings are confusing me because the values don't change when I turn the "tuning" feature on and off. This is in contrast to the actual injection amount used for idle operation.
Translated on 20-08-2026, 13:13.
Roadagain
Post08-11-2005, 10:55    Subject: Injection Molding: What Do These Values Mean? Quote
Thank you in advance for the answers.
The nozzles should be tightly installed. In any case, new seals have been fitted, and there are no external indications that they are leaking.
I also replaced the cables because they were under tension.
I'll measure the compression later. What should the compression reading be for a 1Z engine?
Greetings.
Translated on 20-08-2026, 13:14.
No new posts How exactly does the ESP work? Diesel Engine Technology
No new posts What is PÖL? Definition & Explanation Diesel Engine Technology
No new posts VW Active System: How it Works & Benefits Transmission, Chassis, Body & Interior
No new posts STG Recalibration: What Happens Inside? On-Board Diagnostics (OBD)
