Passat 3BG: No Connection? Troubleshooting Guide
TDI-PanTheR
Post22-11-2005, 21:26    Subject: Passat 3BG: No Connection? Troubleshooting Guide Quote
Good evening.
I am unable to establish a connection to the control units in the Passat.
'When I try to connect, for example, to the engine control unit, it displays the following error messages: 'Adapter Status 2', 'Incorrect COM port setting', 'Adapter not connected', 'Short circuit on the K-line'.'
When switches K1 and K2 are in position, it attempts to connect, but it stops working after a few tries.
When I test the adapter in the options, it says 'Adapter not found' for K1/L.
and for K1/K2: adapter found, IC level shifter or something similar.
The Passat was manufactured in January 2003, has a 130 horsepower TDI engine, an automatic transmission, and climate control.
I just tested the adapter again on my Passat 35i TDI, and everything works fine. It also works without any problems on a Golf 4 TDI from March 2003.
The VAG version is 402, and the adapter is the KKL RS232 adapter available here in the shop.
I hope you can make something of this and help me icon_smile.gif.
panther
Translated on 19-09-2026, 23:19.
Post22-11-2005, 22:04    Subject: Passat 3BG: No Connection? Troubleshooting Guide Quote
Hi Panther,
Please go to the download section (customer account) of the shop; currently, VAG-COM 409.1 is available for your hardware. icon_smile.gif
Regarding your problem: as I see it, the K-line is likely being blocked somehow. Try disconnecting the car's battery for 1 minute (don't forget the radio code) and check if the K-line is accidentally shorted to ground or +12V (e.g., due to improper radio installation).
Translated on 19-09-2026, 23:21.
TDI-PanTheR
Post23-11-2005, 1:49    Subject: Passat 3BG: No Connection? Troubleshooting Guide Quote
How can I tell if the K Line has a short circuit? There's an original VW radio installed in the car.
Will disconnecting the battery for a minute also clear the error memory?
That's something I'd prefer to avoid, if possible.
panther
Translated on 19-09-2026, 23:22.
Post23-11-2005, 10:21    Subject: Passat 3BG: No Connection? Troubleshooting Guide Quote
"Errors are typically stored in the EEPROM, which retains data even when power is lost. I have no idea which control units might be exceptions to this and store errors in RAM instead."
Let me see...
- the voltage at pin 7 in the diagnostic connector relative to ground.
- The short-circuit current from pin 7 to ground should be limited; a 100-ohm resistor would be beneficial to prevent any components in the wiring from burning out in the event of a fault.
Is the diagnostic connector properly seated in the socket? The socket can be larger or smaller depending on the model, and the connector can sometimes be a bit difficult to insert.
Translated on 19-09-2026, 23:23.
No new posts Doku Polo MJ 2002, No Power Steering Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts No Connection to Tax Devices On-Board Diagnostics (OBD)
No new posts Engine Control Unit (ECU) Connection Problem On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. MSG/WFS Golf 3 1Z: No Connection? On-Board Diagnostics (OBD)
No new posts Vagcom303: No Connection to 1Z B4 - Troubleshooting On-Board Diagnostics (OBD)
