Increase Starting Amount: How To & Tips
Markus H.
Post01-11-2002, 21:45    Subject: Increase Starting Amount: How To & Tips Quote
I'm experiencing the exact issue described by Michael-II in the error database under 'Starting Problems' for my AAT engine:
Difficult, rough cold start --> Disconnect the temperature sensor connector --> Perfect starting behavior.
Now, this issue should be resolved after updating the error database and increasing the initial amount.
My question:
Isn't that just treating the symptoms superficially?
I mean, the initial amount is set by the manufacturer in the control unit (ECU), so how can it possibly change on its own to 'too low'?
Actually, shouldn't there be another (mechanical) cause for the cold start problems (e.g., a misadjusted ESP), which is merely masked by the increased fuel injection amount?
Translated on 24-10-2026, 16:51.
Post02-11-2002, 11:27    Subject: Increase Starting Amount: Guide & Tips Quote
My question:
I mean, the initial value is set by the factory in the control unit (STG) and it can't just change itself to "too low", can it?
Hi Markus,
My car since it was delivered starts a little hesitantly when warm, even though everything else seems to be fine (pump settings, performance, etc.). So, it seems to be a problem with the (software) fine-tuning.
Disconnecting the temperature sensor connector significantly improves the warm start, but it also creates an error entry.
If the starting behavior changes gradually, then a quantity correction would only be a superficial fix. In that case, the cause should be identified and, if possible, eliminated.
Translated on 24-10-2026, 16:53.
Markus H.
Post02-11-2002, 14:33    Subject: Increase Starting Amount: How To & Tips Quote
Thank you, Ulf.
The problem is that I've only had the Audi for 2 months.
So, I can hardly tell how long it has been running hesitantly during cold starts.
After the purchase, when it was still warm, there were hardly any problems.
And now it's not a big deal, but that uneven running for a few seconds sounds awful! After that, everything is fine.
Question:
Is this temperature sensor, the one whose connector you can unplug for testing, the same one that also provides the water temperature reading to the combination instrument in the cockpit?
Then it's possible that this sensor is simply defective.
Because my water temperature gauge is consistently reading much lower than it should (I believe the thermostat is working correctly).
Translated on 24-10-2026, 16:55.
Post02-11-2002, 23:12    Subject: Heating System OK? Check Now! Quote
Hi Markus,
Before we go into more detail: Is the glow plug system fully functional? An uneven idle after starting often comes from individual faulty glow plugs.
Translated on 24-10-2026, 16:56.
No new posts Document startup issues, adjusting initial quantity Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Increase initial fuel quantity with VAG-COM on A6 V6 TDI Diesel Engine Technology
No new posts Increase Startup Amount with Diagnostic Tool Diesel Engine Technology
No new posts AFN: Optimal Start Amount (Warm) Range Diesel Engine Technology
No new posts Exact meaning of starting amount (MWB 5, 2) On-Board Diagnostics (OBD)
