ABS Error 00290: Causes and Fixes
gtdpower
Post24-11-2005, 21:52    Subject: ABS Error 00290: Causes and Fixes Quote
Hello everyone,
Since my ABS light occasionally illuminates, I recently read the error codes and found the following:
2 errors found:
00290 - Pressure switch (F116) / Warning contact (F117)
35-10 - - - Intermittent
16-10 - Signal out of tolerance - Intermittent.
However, the error database here indicates that error code 00290 refers to a defective rear left sensor.
Was ist nun richtig? Was ist unter dem Druckschalter gemeint? Where is it located?
Vehicle: Golf III AFN, year of manufacture 1997, with GTI trim (including brakes).
Thank you very much in advance.
Best regards, Nico.
Translated on 28-09-2026, 9:45.
Post24-11-2005, 21:55    Subject: ABS Error 00290: Causes and Fixes Quote
Hi Nico,
Which VAG-COM version, license, and hardware are you using?
Translated on 28-09-2026, 9:47.
gtdpower
Post24-11-2005, 22:33    Subject: ABS Error 00290: Causes and Fixes Quote
The interface is a 'VAG Interface 9141'.
The VAG-Com version is 208.2 and is registered.
Best regards, Nico.
Post25-11-2005, 0:05    Subject: ABS Error 00290: Causes and Fixes Quote
You should consider upgrading your VAG-COM software. Your dealer should be able to provide a free unlock for at least VAG-COM 311.2. That's usually the standard procedure.
The reason I asked about the version is because older, cracked versions sometimes display error messages that don't match the error codes.
Translated on 28-09-2026, 9:48.
gtdpower
Post27-11-2005, 20:10    Subject: ABS Error 00290: Causes and Fixes Quote
Okay, so it seems like the version installed on the laptop is probably a cracked version, or something like that?
I bought the laptop, including the measurement adapter, as a used item.
I have now downloaded version 311 as shareware, and the error number 280 appears, but of course, no text is displayed. Can I assume that the rear left sensor is defective, then?
Is it possible to test this sensor, for example, using a multimeter?
Is the unlocking feature useful from a software perspective? Actually, you can always look up the error codes in this very good forum. If it is useful, what should such an unlocking feature cost for private use? You're practically at the source, aren't you?
Best regards, Nico.
Translated on 28-09-2026, 9:49.
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Error Codes 00290 & 00287 - Ibiza 1999 Electrical Systems, Vehicle Electronics, Multimedia
No new posts ABS and brake warning light, error codes 00290 00688 Transmission, Chassis, Body & Interior
No new posts Clutch judder and GRA with malfunction Diesel Engine Technology
No new posts Airbag malfunction Diesel Engine Technology
