Problem Steuergerätumcodierung AJM mit VAG-COM 3113 | Posts 16+
Go to page: Previous  1, 2
Post28-11-2005, 14:06    Subject: Quote
Boost pressure logging at idle: pointless, the engine needs to be under full load...
Translated on 28-09-2026, 13:29.
Troubleshooter
Post28-11-2005, 17:53    Subject: Quote
When removing the ECU, there are tools that allow programming the flash memory without desoldering. It's possible that something like that was done to your ECU.
Best regards, Rudi
'However, even with a bench adapter, nothing works with the older EDC15 models (with 6 Torx screws). But maybe there are actually some 019BJ models with a new EDC15.'
@ttns4
Remove the plastic cover and take a look at the ECU; I'd like to see it.
Matthias.
Translated on 28-09-2026, 13:30.
ttns4
Post29-11-2005, 9:38    Subject: Quote
However, when removing the ECU, there are tools that allow programming the flash memory without desoldering. It's possible that something like that was done to your ECU.
Best regards, Rudi
@ttns4
Matthias
Okay, the control unit has never been opened, it has an aluminum casing, that's what I remember.
I had the engine control unit removed back then to have it flashed with new software.
'I might have been lucky; mine is a 2000 model, manufactured in June 1999.'
ttns4
Translated on 28-09-2026, 13:32.
Troubleshooter
Post29-11-2005, 13:23    Subject: Quote
ttns4
4 or 6 screws?
Greetings.
Matthias.
Translated on 28-09-2026, 13:34.
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission Problems: Audi A4 01N AFN General Tips
No new posts Fixed Issue, New Problem Arises Diesel Engine Technology
No new posts Graphics Card Issues: Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts WFS Issues: Troubleshooting and Solutions On-Board Diagnostics (OBD)
No new posts VAG-COM Issues: Audi A4 Troubleshooting Guide On-Board Diagnostics (OBD)
