Hazet 2592: Use and Applications
Post01-12-2005, 14:15    Subject: Hazet 2592: Use and Applications Quote
the Hazet 2592
http://www.hazet.de/deutsch/katalog/suche_3.asp?F=2592&H=100&U=303
Is there also a multi-tooth adapter for the alternator shaft?
Unfortunately, I can't find any more information about it, because I already have the 2592. Now, I just need to know what type of multi-tooth wrench I still need to hold the shaft in place.
Background: Installing a 120A Bosch alternator on a 1Z engine, replacing the freewheel with part number 028 903 119 AA.
Thank you.
Translated on 23-08-2026, 16:54.
Boro
dieselmartin likes this.
Post01-12-2005, 14:29    Subject: Hazet 2592: Use and Applications Quote
Was war dieser https://community.dieselschrauber.org/en/viewtopic.php?p=71101&highlight=#71101 thread here?!
You'll find everything there!
Translated on 23-08-2026, 16:55.
Post01-12-2005, 14:35    Subject: Hazet 2592: Use and Applications Quote
If you look hard enough, you can find it at HAZET too.
http://www.hazet.de/deutsch/katalog/suche_3.asp?F=4641%2F2&H=10&U=100
found via Google search using the terms "2592 "two-piece set"".
It couldn't be found using only the search term "Hazet 2592".
Thanks, Boro - I've added it to the old thread.
Translated on 23-08-2026, 16:56.
Post01-12-2005, 14:46    Subject: Hazet 2592: Use and Applications Quote
Guckt Euch mal das PDF aus o.g. [Please provide the text you would like me to translate from German to English.]
http://www.hazet.de/prod_pdf/081/081479ba.pdf
That Allen key looks a lot like a star-shaped bit, is that a Torx screw?
Translated on 23-08-2026, 16:57.
Rudi
Post01-12-2005, 16:06    Subject: Hazet 2592: Use and Applications Quote
Okay, I see a multi-tooth wrench...
Torx screws are also used; Valeo offers free-wheeling alternators (e.g., in the 85 kW PD Passat).
Rudi
Post02-12-2005, 10:57    Subject: Hazet 2592: Use and Applications Quote
Okay, so I bought a used VW Golf (the one I thought I had, I couldn't find).
"Unfortunately," there was only Gedore available, so I spent 10 EUR and got one more awesome tool icon_smile.gif.
Now I also think that the PDF shows a multi-tooth gear icon_exclaim.gif.
 File size:  13.92 KB
 Viewed:  3486 times
Translated on 23-08-2026, 16:58.
No new posts Timing Belt Replacement ATJ, Hazet Crankshaft Stopper Diesel Engine Technology
No new posts Wheel bearing tool Hazet 4930, no strut removal required? Transmission, Chassis, Body & Interior
No new posts I am looking for an installation manual for an electric t... Diesel Engine Technology
No new posts Window Regulator for VW Golf 4 Transmission, Chassis, Body & Interior
