Leistungsloch 1Z | Posts 16+
Go to page: Previous  1, 2
kapselchrissi
Post14-12-2005, 12:21    Subject: Quote
Bought a magnetic solenoid valve for €33, installed it, and everything is perfect... Thank you, thank you, thank you...
It can be this easy. X
Translated on 17-09-2026, 8:01.
Post14-12-2005, 14:20    Subject: Quote
Sure, no problem!
And thank you for the feedback.
Do you still have the old one?
Can you determine what is broken?
I always thought that if this part fails, it would cause the turbocharger to only produce the design-specified 0.6 bar of boost, essentially sending full boost pressure to the wastegate.
It seems your N75 valve failed in a way that prevented any boost pressure from being applied to the wastegate.
Translated on 17-09-2026, 8:02.
kapselchrissi
Post15-12-2005, 16:34    Subject: Quote
I'll take a closer look at it sometime this week and see what's inside. I'm also curious to see what's in it, especially since that little thing caused me so much trouble icon_redface.gif.
Translated on 17-09-2026, 8:03.
Post15-12-2005, 16:51    Subject: Quote
I think that if you dissect it, my question will no longer be answerable.
Mouth-to-valve ventilation is more appropriate in this case.
When you hold it, the connectors will likely appear to be translucent, with a black and blue tint.
black = outside air
Red = Charge air.
blue = wastegate
kapselchrissi
Post15-12-2005, 22:05    Subject: Quote
I took a more delicate approach... using a saw, a pair of side cutters, and a chisel.
Result: The spring was broken where the two connectors are located on one side. The opening valve is mounted on a spring, which is supposed to move the valve housing to the open position. The spring was broken at the bottom. It probably still functioned for a while after that. You can see that the two spring parts wore each other down until they eventually jammed. This prevented any valve movement due to induction. For those who don't know what the part looks like when it's open, here's a picture.
I hope I was able to contribute something productive now icon_biggrin.gif.
 File size:  74.28 KB
 Viewed:  2611 times
Translated on 17-09-2026, 8:05.
Stummel
Post17-12-2005, 20:58    Subject: Quote
hiho
I have a question about the 1Z/AHU engine. I was just playing around with VAG-COM and noticed two values in a measurement block (which I think are boost pressure). Sometimes, the value is above 2100 mbar, even though it should only be around 19xx mbar. Is this normal?
'And something else I noticed: could it be that when accelerating under full load, the system starts reducing the boost pressure at some point, although I don't know the exact RPM? I could see that one value (the target value) had already decreased, even though the actual pressure hadn't yet reached the target. Is this some kind of protection to prevent it from hitting the rev limiter?'
Translated on 17-09-2026, 8:06.
No new posts Engine Misfire at 2800 RPM Diesel Engine Technology
No new posts TDI Performance Issues: Troubleshooting Guide Diesel Engine Technology
No new posts A4 AFN: Minimizing Performance Gap Diesel Engine Technology
This topic is locked, you cannot edit or reply. Audi A4 1.9 TDI: Performance Issues & Solutions Diesel Engine Technology
