Radio won't turn off? Troubleshooting tips
herold4
Karma: +4 / -1   Thank you, like it!
Post11-12-2005, 18:35    Subject: Radio won't turn off? Troubleshooting tips Quote
Hello, I've already searched the history, but I couldn't find anything related to my error.
This concerns an Audi A3, model year 2002, which has a Chorus system installed.
The problem manifests as follows: I can turn the radio on using the power button.
But if I remove the ignition key, it keeps playing.
Now I've removed the device and discovered that there is no S-contact.
more than that, in my opinion, all of that stuff goes through a data bus icon_question.gif.
Replacing the device did not bring any success either icon_sad.gif.
Okay, I've now read the error memory (for the radio), and there's an entry indicating a problem with the data bus in the control panel.
Has anyone ever experienced a problem like this before icon_question.gif?
And it solved icon_smile.gif.
Translated on 16-09-2026, 3:34.
herold4
dieselschrauber and
Post17-12-2005, 14:22    Subject: Solution: Find the Answer Now! Quote
Solution!!!!!!!!!!!!!!
I wanted to follow up and let you know that the problem was indeed the data bus, which could be identified by the uppermost connector socket on the radio.
This information can also be found in the wiring diagram of the radio housing (CAN). When I tried to measure the data bus at these pins...
(Using a quick oscilloscope), I saw only 9 volts with the ignition on, and no data signal. This led me to suspect that...
The combination is defective because the S-signal was supposed to arrive there! (Think again.) icon_evil.gif
Unfortunately, it's necessary to register the bus devices in the instrument cluster, which probably hasn't been done in my case.
"This was done, because I can't imagine that the instrument cluster would forget its coding!"
    Control units on the data bus.
    Code.
    Combination instrument and...
    CAN-compatible radio 1
    Wall-mounted telephone 2
    with multi-function steering wheel.
    CAN-enabled radio +
    Wall-mounted telephone.
    with multifunction steering wheel 3
    CAN-compatible radio.
    Nav.Ns-Low or
    Combination instrument and 5
    Nav RNS-D
    (Screen)
    CAN-compatible radio/navigation system - Low price range 7
    Fixed-installation telephone.
    with multifunction steering wheel.
    or combination instrument.
    Nav. RNS-D.
    (Screen navigation)
    Telematics without a multi-function steering wheel. 9
    Telematics 11
    Nav.Ns-Low / Telematics
    Without a multi-function steering wheel.
    or combination instrument and 13.
    CAN-enabled radio telematics.
    without multi-function steering wheel.
    or combination instrument and 15.
    Nav RNS-D
    (Screen)
All original Audi radios from the model year 2002 onwards are CAN-bus compatible.
The table applies to vehicles manufactured from 2002 onwards.
Translated on 16-09-2026, 3:39.
Post17-12-2005, 19:41    Subject: Solution: [Problem/Question] Solved! Quote
herold4 wrote:
I wanted to follow up and let you know that the problem was indeed the data bus, which can be identified by the uppermost connector socket on the radio.
Thank you for the solution!
Translated on 16-09-2026, 3:44.
mahk
Avatar-mahk
Post18-12-2005, 12:20    Subject: Radio won't turn off? Troubleshooting tips Quote
Perhaps a little off-topic, but if someone finds this article while searching, they will probably be interested in this link (it has certainly helped me before): http://www.selfmadehifi.de/kfz-iso.htm icon_idea.gif
Typ89 SB: 05/2000 120.000km - 01/2005 295.000km (unfall)
B5 Avant AEB 07/2005 166.000km ([email protected]) - 07/2007 195.000km (verkauft)
1K BMM: 03/2011 120.000 km - aktuell
No new posts A2 Radio: Won't Turn On After Parking? (8Z0) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Smart Fortwo: Gear won't shift from Neutral to Drive General Tips
No new posts The radio won't turn off Electrical Systems, Vehicle Electronics, Multimedia
No new posts Automatic Transmission Not Shifting? Fix It! Diesel Engine Technology
No new posts Lupo 3L: Won't shift to 5th gear Transmission, Chassis, Body & Interior
No new posts VAG 1552 K-line not switching to positive On-Board Diagnostics (OBD)
