Cozmo2010
Joined: 12/29/2005 Posts: 9 Karma: +0 / -1 Location: Hamburg
29-12-2005, 15:43 Subject: Diagnosis: Acquisition |
I would like to purchase a laptop or diagnostic device that allows me to read all error codes.
It's enough if it works with Golf 3 models or later.
Okay, I need some tips and suggestions from you about what I'll need for this.
Sure, here's the translation:
"Thank you in advance." Gruß, Coschi
29-12-2005, 16:23 Subject: Diagnosis: Acquisition |
Profile PM Garage |
Cozmo2010
29-12-2005, 16:49 Subject: Diagnosis: Acquisition |
Oops.
I didn't want to spend that much! Gruß, Coschi
mullemaus Guest
29-12-2005, 17:49 Subject: Diagnosis: Acquisition |
Then buy a laptop (e.g., on eBay) and, in the shop shown above, purchase an interface and the corresponding software. That will also  .
Cozmo2010
29-12-2005, 18:17 Subject: Diagnosis: Acquisition |
Okay... I'd rather do that with a laptop!
What requirements should a notebook meet in order to be suitable for that purpose? Gruß, Coschi
mullemaus Guest
29-12-2005, 18:45 Subject: Diagnosis: Acquisition |
A Pentium II should be sufficient. You should pay attention to a good battery.
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
29-12-2005, 20:16 Subject: Diagnosis: Acquisition |
You can find the hardware requirements here (section 1.4 for serial adapters, 1.5 for USB).
http://www.ross-tech.com/vag-com/faq_1.html#1.4Gruß
Profile PM Garage |
Cozmo2010
29-12-2005, 20:23 Subject: Diagnosis: Acquisition |
Okay.
Okay, now I know what kind of laptop I need!
What cables or adapters do I need to be able to use the 2x2 connection in my Golf 3?
and which cables are needed to connect to newer cars? Gruß, Coschi
29-12-2005, 20:59 Subject: Diagnosis: Acquisition |
"This isn't a simple question to answer. "Newer cars" often have CAN bus diagnostics and require a CAN-compatible interface, such as the Golf 5, new A3 models, Touran, etc."
All interfaces come with the 16-pin OBD2 connector. For 2x2 sockets, corresponding adapters are available here in the shop http://shop.dieselschrauber.de/product_info.php/products_id/34.
Please note that newer versions of VAG-Com, specifically those above version 3.11, can only be used or unlocked in conjunction with intelligent interfaces that have a built-in dongle. Gruß
Profile PM Garage |
Cozmo2010
29-12-2005, 21:35 Subject: Diagnosis: Acquisition |
Okay, then I'll focus on the models up to the year 2000, was probably the limit, right? If so, what do I need? Gruß, Coschi
29-12-2005, 22:23 Subject: Diagnosis: Acquisition |
Profile PM Garage |
Cozmo2010
29-12-2005, 22:26 Subject: Diagnosis: Acquisition |
Okay, then I know the basics.
THANK YOU VERY MUCH! Gruß, Coschi
