Motor AFN - AGR control unit - will it fit?
MarcR
Post03-01-2006, 10:05    Subject: Motor AFN - AGR control unit - will it fit? Quote
I have an engine from a 1998 Audi A4 Avant with SG number: 038 906 018 S. Someone has offered me an SG from a Golf (supposedly a Golf 4) with SG number 028 906 018 BG. The engine code is AGR. Will the software be compatible? Sure, things like the immobilizer need to be programmed, but I'm more concerned about the software that's already installed.
Marc.
VW 183-01, Iltis, 1.8l Benziner
(wird baöd zu 1.9l TDi, 1Z)
Rudi
Post03-01-2006, 11:36    Subject: Motor AFN - AGR control unit - will it fit? Quote
It might work (he will run it), but you should be prepared for error messages.
However, the AFN software should run within the STG.
Perhaps you could find a reputable tuner (not a chip copying service) near you who can...
the original 018S implant was used. The world shouldn't cost anything.
(If it's a larger store, you could offer them the option of placing advertisements on the Iltis.)
Maybe they will then support you in other ways icon_wink.gif).
Rudi
Post03-01-2006, 16:57    Subject: Motor AFN - AGR control unit - will it fit? Quote
Just the fact that someone is offering you a Golf 3 engine control unit (ECU) and claiming it's a Golf 4 unit would make me suspicious.
To my knowledge, the Golf 4 did not have any "028.." engine control units (ECUs), but only 038 series ECUs.
Rudi
Post03-01-2006, 17:11    Subject: Motor AFN - AGR control unit - will it fit? Quote
Hi Martin,
He probably just mistyped it. 018 was never included in the G3.
Rudi
MarcR
Post03-01-2006, 22:21    Subject: Motor AFN - AGR control unit - will it fit? Quote
Hello everyone,
Thank you for the answers so far.
Rudi wrote:
Hi Martin,
Best regards, Rudi
Hi Rudi, if you know that, I'm wondering where you got that information from. Do you have a list of SG numbers and where they were used? That would be very helpful to me.
Sure,
Marc.
SD16
Post03-01-2006, 23:11    Subject: Motor AFN - AGR control unit - will it fit? Quote
For example, you can find information like that in the Bosch ESI.
There are more programs available.
Rudi
Post04-01-2006, 0:43    Subject: Motor AFN - AGR control unit - will it fit? Quote
Hi Rudi, if you know that, I wonder where you found out. Do you have a list of the SG numbers and where they were installed? That would help me a lot.
I don't have a list in that sense. This is more like accumulated trivia that builds up over time.
if one deals with the subject matter.
Otherwise, it's pretty much as SD16 wrote.
Rudi
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Which Control Unit Fits? Find the Right ECU! On-Board Diagnostics (OBD)
No new posts Which engine fits? Diesel Engine Technology
No new posts Ford Galaxy Engine: Which One Fits? Diesel Engine Technology
No new posts Engine for Galaxy 1Z/AHU: Which one fits? Diesel Engine Technology
