Hi everyone,
My Passat Variant 3B AFN, with a PSI power box (
6 kW), mileage: [insert mileage here].
It's missing about 50 horsepower 'from the bottom end.' The car has never really felt like a proper TDI, which is why I installed a new mass airflow sensor (MAF) and a PSI box at the beginning of the year. It improved after that, but not really significantly. (I took it to the VAG workshop, and the master mechanic said everything was fine, so I believed him).
Okay, so I just had a rental car because someone rear-ended my car (A4 Variant, 130 hp) - the difference in acceleration, especially from a standstill, was SO SIGNIFICANT that I'm sure something is wrong with my car. In the A4, I could really feel how the turbo kicks in around 1300 rpm and develops a lot of power - a feeling that I don't get in my Passat. Furthermore, in the A4, I only needed to move the accelerator pedal in the first third of its range to get going quickly. In my Passat, on the other hand, I have to press the pedal all the way to the last third of its range to get any decent acceleration.
The Passat's engine also sounds louder and 'rougher.'
Otherwise, the Passat exhibits the following 'behavior':
- Light smoke (rather pale) when starting the engine and driving away with little acceleration.
- slight (dark) smoke when running at full power (only visible in the headlights of following vehicles).
- starts well, doesn't jerk.
- Reaches a top speed of approximately 210 km/h according to the speedometer, but very slowly, and it's not consistent.
sometimes, in cold weather, it goes into emergency mode.
- Achieved a top speed of 195 km/h (as indicated by the speedometer) without the use of a trailer.
- is slightly below the target values for the DZR.
- During the last inspection, the following error codes were stored in the system's memory:
01268 035
Quantity setting - N146.
what was placed on the box.
- Sometimes the engine doesn't respond to the accelerator pedal, for example, I'm driving on the highway at a constant speed and then gently press the accelerator, but nothing happens. If I press the accelerator even further, there's suddenly a sudden surge of power. (This happens very rarely).
What would you suggest I do? Since the car is objectively performing reasonably well (in terms of maximum speed), and my descriptions of the problems are more subjective, I'm likely to be told by the workshop that 'everything is okay.' Unfortunately, I'm not very mechanically inclined and can't fix much myself.
Perhaps someone from around here (Bad Zwischenahn) can recommend a COMPETENT workshop?
Are there any possible explanations for the cause of the error?
Any other ideas?
Sorry for the long essay, but I wanted to convey as much information as possible.
Hoping for good advice/ideas,
Jens.
