Coolant Temperature Measurement: How To & Guide
UdoZ
Post23-01-2006, 11:35    Subject: Coolant Temperature Measurement: How To & Guide Quote
Hi there,
and one more question about the measurement icon_wink.gif.
Since I initially don't have a free 'port' in the flange for another temperature sensor, I want to first measure the coolant temperature using a sensor attached to the coolant hose near the flange where the original sensors are located. It's a relatively slow system. However, even with insulation, the surface of the hose is unlikely to heat up significantly to reflect the actual coolant temperature.
Does anyone have a quantitative estimate of the expected measurement error?
Thank you, zaydo.
Translated on 29-07-2026, 10:48.
TDI-Peter
Post26-01-2006, 18:13    Subject: Coolant Temperature Measurement: How To & Guide Quote
I have installed a bimetallic temperature switch with insulation on the inlet of the heating cooler for my auxiliary heater.
The temperature switch turns off at 57°C (measured in a water bath using a digital thermometer).
The valve is installed separately with an insulation sleeve (made of foam commonly used in heating systems, approximately 1 cm thick) and activates at a coolant temperature of 68°C (measured using VAG-COM).
Perhaps this will help you.
Greetings.
Peter.
96er Passat Variant
90 PS (1Z)
Automatik
Translated on 29-07-2026, 10:50.
UdoZ
Post26-01-2006, 20:47    Subject: Coolant Temperature Measurement: How To & Guide Quote
Hi Peter,
Maybe this will help you.
Yes, definitely.
However, the result is somewhat disappointing. I had expected/hoped it would be lower.
Thank you very much, zaydo.
Translated on 29-07-2026, 10:51.
No new posts Coolant Temperature AMF Diesel Engine Technology
No new posts VAGCOM and Coolant Temperature Diesel Engine Technology
No new posts Coolant Temperature Sensor: Buy Now! On-Board Diagnostics (OBD)
No new posts A6 C6 Coolant Temperature Error Gasoline Engine Technology
