stephankagi
Joined: 02/15/2006 Posts: 6 Karma: +0 / -0 Location: weilmünster
15-02-2006, 15:28 Subject: Dashboard Lights On? Fix It Now! |
Hello! I hope someone can help me! I have a Lupo 3L TDI, manufactured in November 1999, with 196,500 km on the odometer. About three weeks ago, I had a problem with the immobilizer; the security mechanism came loose. I replaced it, and then everything worked again. Then, I took the car to my brother's workshop for an inspection. While he was driving there, all the warning lights in the dashboard suddenly turned on. My brother checked at the workshop, read the error codes, but found nothing. He removed all the interior panels and looked for damaged cables, but found nothing. He disconnected the battery. When he reconnected it, everything seemed to be working again. Now, two weeks later and after about 1300 km, I was driving on the highway when suddenly the speedometer needle started jumping wildly up and down. The engine also felt sluggish and had a noticeable lack of power. However, I still had 300 km to go, and when I got home, the speedometer stopped working completely. As I said, I can remove the key, but the lights remain on. I've even tried disconnecting the ignition switch, but it's the same problem! Now, I have to disconnect the battery overnight. I don't know what else to do and I don't know any workshops that are familiar with the Lupo. Can anyone help me?
Translated on 16-08-2026, 2:18.
Rudi Guest
15-02-2006, 16:14 Subject: Dashboard Lights On? Fix It Now! |
Hello Stephan,
Could there possibly be a connection to the weather conditions (rain, snow, dew, etc.), such that moisture has entered the tachometer unit?
Coolant level is normal and everything under the floor mats is dry?
Rudi
Translated on 16-08-2026, 2:20.
stephankagi
15-02-2006, 16:54 Subject: Dashboard Lights On? Fix It Now! |
Hello Rudi!
Okay, the interior of the vehicle is completely dry, so I don't think it's related to that. However, I'm wondering where the electricity is coming from if I disconnected the ignition switch.
Translated on 16-08-2026, 2:21.
Rudi Guest
15-02-2006, 17:06 Subject: Dashboard Lights On? Fix It Now! |
The speedometer is permanently powered (which is how, for example, the trip odometer remembers its value).
and the clock is also attached to it.
If there's now water flowing where it shouldn't be, there must be a reason for it.
Based on how you're describing it, I would suspect moisture.
Unfortunately, I'm not very familiar with the Lupo. Therefore, I can't tell you where the best places to stop for a break are.
...or where water enters and, if in doubt, also exits.
Most of the instruments, as well as the lights, are powered by the speedometer.
If necessary, you may need to remove the tachometer unit and inspect it for moisture.
Rudi
Translated on 16-08-2026, 2:22.
stephankagi
15-02-2006, 17:56 Subject: Dashboard Lights On? Fix It Now! |
Yes, that doesn't sound too difficult! I'll look into it tomorrow and take everything apart to see what I can find (hopefully).
Okay, I definitely thank you for your help, and I will write to you tomorrow to let you know if I have found anything.
Translated on 16-08-2026, 2:24.
bloesch Profi-Schrauber
Joined: 03/18/2005 Posts: 622 Karma: +16 / -0 Location: FL
15-02-2006, 18:00 Subject: Dashboard Lights On? Fix It Now! |
Oh... that would also be interesting for me... especially how the combination [or system] is developed.
"In my car, the speedometer occasionally drops to zero for a short time when the touch-sensitive function is used."
Rudi Guest
15-02-2006, 19:56 Subject: Dashboard Lights On? Fix It Now! |
I was looking for something earlier.
Maybe this will help you a little bit further.
The screws for the trim should be located where the arrows point.
Then the speedometer will only be held in place by two screws on the top edge.
Rudi
| Description: |
| File size: |
115.44 KB |
| Viewed: |
5390 times |
Translated on 16-08-2026, 2:25.
15-02-2006, 20:43 Subject: Dashboard Lights On? Fix It Now! |
huge thanks
.oO( I never even noticed those screws before...)
Translated on 16-08-2026, 2:26.
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
15-02-2006, 22:12 Subject: Dashboard Lights On? Fix It Now! |
A possible cause could be a faulty ignition switch located directly behind the main ignition switch.
NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Profile PM Email Garage |
stephankagi
15-02-2006, 22:26 Subject: Dashboard Lights On? Fix It Now! |
Thanks, Rudi, that definitely helps me! I'll take a look tomorrow.
"@T3Surfer is another option that I will check." THANK YOU.
Translated on 16-08-2026, 2:27.
stephankagi
16-02-2006, 14:33 Subject: Dashboard Lights On? Fix It Now! |
 Hello!
Okay, I removed my dashboard about 1.5 hours ago, and it's absolutely no problem! So far, everything seems to be in order based on what I can see visually. Anyway, I thought, "Let's take out the entire dashboard!" But I advise you: if you don't have to, just leave it alone!!! There are so many screws used; I think half of them would have been enough! And I'm not even finished yet! In any case, I noticed that the footwell on the passenger side is completely soaked! So, there must be some kind of short circuit. I don't really know where the water is coming from, but I suspect it might be from the rear windshield washer nozzle because it's not working, and the hose probably runs through the roof beam, right?
"@T3Surfer I couldn't find any ignition switches behind the ignition lock."
Translated on 16-08-2026, 2:28.
R00KIE Guest
16-02-2006, 14:50 Subject: Dashboard Lights On? Fix It Now! |
To the best of my knowledge, the drain pipe for the washing machine runs along the left side, underneath the 'entry strip.'
'I had water ingress issues with my Golf 3 twice. The first time, a drain pipe from the sunroof was blocked. The second time, leaves in the water collection tray, along with an apparently misaligned interior filter box, caused the problem. The leaves blocked the drainage, and when the water level rose a few centimeters, the seal on the tray gave way, allowing the water to find its way through the fan motor.'
It's possible that the Lupo is built in a similar way.
Translated on 16-08-2026, 2:29.
16-02-2006, 17:27 Subject: Dashboard Lights On? Fix It Now! |
Quote: | | Anyway, I've noticed that the footwell on the passenger side is completely soaked! |
"Maybe you should focus on the plastic container on the passenger side instead! That's where the engine control unit is located, so make sure it hasn't gotten soaked."
The windshield washer hose indeed runs to the left, along the side. It goes under the carpet and then up the metal panel next to the rear seats. There, approximately at chest height of the person sitting in the back seat, is also the windshield washer coupling (as well as a connector for the rear window heater... all together in foam, where water tends to collect  ).
Translated on 16-08-2026, 2:31.
stephankagi
16-02-2006, 17:53 Subject: Dashboard Lights On? Fix It Now! |
Okay, so I removed the completely soaked felt mat that was between the floor pan and the interior lining so I could dry out the rest of it. Now the problem with the dashboard lights constantly being on is gone, but now the speedometer isn't working anymore. Hopefully, it hasn't been damaged. Does anyone know how to test it?
Is the coolant reservoir located in the engine compartment?
Translated on 16-08-2026, 2:32.
R00KIE Guest
16-02-2006, 18:21 Subject: Dashboard Lights On? Fix It Now! |
The windshield washer reservoir is located directly in front of the windshield, so you will need to remove the windshield wipers to be able to take off the entire cover.
On the left side, there's also a smaller cover that is secured with 3-4 screws; underneath it, you should find the internal filter if one is present.
The coolant temperature sensor (MSG) is located in the middle of the coolant reservoir (at least on the 1.4 TDI engine).
Translated on 16-08-2026, 2:33.
