Bypass Valve Motor: Repair & Access (VW Golf)
siliconsensing
Post14-02-2006, 15:11    Subject: Bypass Valve Motor: Repair & Access (VW Golf) Quote
To my dismay, the recirculation flap motor in my Golf IV has failed and is making unpleasant rattling noises.
I tried to reach it, but the part is located very deep under the dashboard.
Does anyone have any ideas on how I can proceed?
Is this a known issue or an isolated incident?
Translated on 26-09-2026, 18:24.
Post14-02-2006, 15:54    Subject: Bypass Valve Motor: Repair & Access (VW Golf) Quote
Okay, so it's located on the far right. Remove the glove compartment (open the flap, there are 3 screws on the top side and 4 screws from the bottom) and then take a look inside the opening. You should now be able to see the adjustment motor on the far right. It's secured with a single screw.
Translated on 26-09-2026, 18:25.
siliconsensing
Post14-02-2006, 16:09    Subject: Bypass Valve Motor: Repair & Access (VW Golf) Quote
Thanks for the tip, I'll check it out there!
Translated on 26-09-2026, 18:26.
Holger247
Post20-02-2006, 16:42    Subject: Bypass Valve Motor: Repair & Access (VW Golf) Quote
Unfortunately, you will probably also need to remove the center console (around the gear lever and ashtray) because one of the screws for the glove compartment is unfortunately hidden by it.
GIV - 98 - ALH
Touran 5T 2.0 TDI
Post20-02-2006, 17:35    Subject: Bypass Valve Motor: Repair & Access (VW Golf) Quote
It doesn't apply to me, and according to the repair manual, it doesn't apply either!
Holger247
Post21-02-2006, 8:48    Subject: Bypass Valve Motor: Repair & Access (VW Golf) Quote
It's funny, but it definitely happened that way for me.
Perhaps this was changed in later years of production?
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 26-09-2026, 18:27.
pschaefer
Post21-02-2006, 11:20    Subject: Bypass Valve Motor: Repair & Access (VW Golf) Quote
It was the same for me. To access the glove compartment, I had to disassemble everything from the left side. While I was at it, I also installed my hands-free device.
Post21-02-2006, 11:38    Subject: Bypass Valve Motor: Repair & Access (VW Golf) Quote
Okay, interesting. Well, in my case, it's the screws at the top and bottom. I know this because I recently spent some time repairing my glove compartment light, as that thing fell apart during a bulb change. Also, my glove compartment doesn't stay closed properly anymore because my niece was in a hurry when opening it once. If you're experiencing the same problem, there was a small plastic strip broken off inside the guide, which the guide slides along. Even though it wasn't a professional solution, I used hot glue to fill the gap, and it now slowly closes again.
Translated on 26-09-2026, 18:28.
No new posts TDI: Frequent Regeneration? Where Does All the Soot Come ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Clutch Pedal Not Returning Fully Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL Engine: How Speed Signal Reaches the Gauge. On-Board Diagnostics (OBD)
No new posts A6 (C4): Location of recirculation valve. Transmission, Chassis, Body & Interior
No new posts Blower Motor Resistor for VW Golf IV: Location Transmission, Chassis, Body & Interior
No new posts 2.0 TDI AGR Valve: Faulty & Replacement Guide Diesel Engine Technology
