That's correct, as Besswerwisser wrote .
(However, it also works like this: Old adjustment value * calculated consumption / old display value = New adjustment value ).
In my case, it's quite accurate.
100 * 8 / 8.4 = 95 -> which means that with 95, I'm pretty much spot on (as I mentioned above).
I have also increased channel 30 in two stages to now 165, and I am gradually approaching my maximum tank volume.
I've now increased the fuel pump setting from channel 30 to 180, gradually approaching my car's maximum fuel capacity. It's now taking 65 liters of fuel when the remaining range shows 30 km, but the tank's nominal capacity is supposed to be 72 liters -> ?
Can anyone tell me something about Kanal 33 (Volleichung)?
'I completely filled up the tank today, and according to VAGCOM, it took 68 liters. Neither adjusting channel 30 nor channel 33 changed the reading from 68 liters. Can anyone please help me with this?'
