mfdk Guest
14-11-2002, 18:55 Subject: V6 TDI: Differences between engine codes AFB and AKN |
Since I now own a Passat with the V6 AKN engine, I'm interested in knowing what the differences are compared to the AFB engine.
Thank you in advance.
mfdk
Translated on 16-07-2026, 7:41.
godot Guest
16-11-2002, 21:29 Subject: V6 TDI: Differences between engine codes AFB and AKN |
The number of pump plungers in the radial piston distributor injection pump has been increased by one. This increases the maximum injection pressure. In addition, it features six-hole instead of five-hole injectors and an improved crankcase ventilation system.
At least the first two measures likely serve to comply with the EU III emission standard.
Christian.
Translated on 16-07-2026, 7:42.
mfdk Guest
17-11-2002, 15:38 Subject: V6 TDI: Differences between engine codes AFB and AKN |
Hello!
I am pleased that there is someone in this very competent and interesting forum who knew the answer to my question and made a contribution.
Thank you very much.
mfdk
Translated on 16-07-2026, 7:43.
