No power after removing the EGR valve on an AFN TDI
MONCHI
Post18-11-2002, 10:30    Subject: No power after removing the EGR valve on an AFN TDI Quote
Hey everyone,
I tried disabling the EGR valve on my 110 hp AFN TDI this weekend.
I disconnected the vacuum hose from the turbocharger and plugged it with something. Then I started the car, but the turbo didn't engage at all, meaning the ignition was on but the engine was in limp mode!
What did I do wrong????? I reattached the hose to the can and everything went back to normal!!!!
Thank you in advance for your help!!
Monchi.
Translated on 12-07-2026, 9:28.
Post18-11-2002, 11:14    Subject: No power after removing the EGR valve on an AFN TDI Quote
You probably have:
- picked the wrong hose.
- or the wrong end was closed.
Translated on 12-07-2026, 9:31.
Gremlin
Post18-11-2002, 13:16    Subject: No power after removing the EGR valve on an AFN TDI Quote
Either that, or the EDC actually detected the 'faulty' EGR valve.
While it shouldn't happen in Germany, but in the US, there will be emergency procedures and flashing indicator lights.
Ultimately, the expected and actual air mass no longer match.
I'd like to know more about the error message.
CU Gremlin.
Translated on 12-07-2026, 9:32.
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2263 - Turbocharger/Compressor, System: No Power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 4Motion keine Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AXE Performance Issues After PD Migration Diesel Engine Technology
No new posts TDI No Power After Start - Troubleshooting Diesel Engine Technology
No new posts 2.5 TDI - No power after head replacement / Starting issues Diesel Engine Technology
No new posts Audi C4 AAT : keine Leistung nach 3 monatigem Stillstand Diesel Engine Technology
