Diakon
Joined: 01/26/2006 Posts: 2 Karma: +0 / -0 Location: Senden
27-03-2006, 21:24 Subject: AC Compressor Not Working: Troubleshooting Guide |
Hello everyone,
"The manual air conditioning system in my Audi is defective. I tried to query the control unit for the air conditioning compressor using VAG Com 512.2, following the repair manual and using address 08. The response from VAG Com is: 'Controller uses unknown protocol. Protocol keyword: FF01'."
Could it be that VAG COM is unable to access the control unit? If so, then the unit is probably defective. Where exactly is the control unit located? Audi Cabrio 1,9TDI EZ09/99 MKB:AHU
Translated on 01-10-2026, 2:48.
Ross-Tech-Support Profi-Schrauber
27-03-2006, 22:07 Subject: AC Compressor Not Working: Troubleshooting Guide |
Translated on 01-10-2026, 2:49.
Hartmut K.
28-03-2006, 10:22 Subject: AC Compressor Not Working: Troubleshooting Guide |
Hi! Regardless of the diagnosis: have you checked the system pressure in the air conditioning system? If you bypass the pressure switch and the compressor then starts, the air conditioning system needs to be refilled and checked for leaks. Best regards, Hartmut.
wolfi_b Profi-Schrauber
28-03-2006, 13:05 Subject: AC Compressor Not Working: Troubleshooting Guide |
Yes, the manual climate control system in the Audi 80 is actually diagnosable and can even access some data blocks. The control unit is located behind the storage compartment under the steering wheel and looks like an oversized relay. 1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 01-10-2026, 2:50.
Zak1976
Joined: 03/09/2005 Posts: 225 Karma: +0 / -1 Location: Barendorf
28-03-2006, 22:03 Subject: AC Compressor Not Working: Troubleshooting Guide |
First, I would check the fuses. Second, you could try applying voltage directly to the solenoid valve; you should then be able to hear it engage. If that works, check the wiring harness. Fährt mit Golf 3 TDI Umbau (von AFN auf ARL)
Profile PM Email |
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
29-03-2006, 18:14 Subject: AC Compressor Not Working: Troubleshooting Guide |
"As Harmut K. wrote: Definitely not enough refrigerant in the system! If the compressor were to continue running without refrigerant, it would soon break down... So, take it to a climate control service!" NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 01-10-2026, 2:51.
Profile PM Email Garage |
