Rear Axle Noise Audi A4 B5
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
bastion
Karma: +6 / -1   Thank you, like it!
Post30-03-2006, 13:38    Subject: Rear Axle Noise Audi A4 B5 Quote
"I'm experiencing a rattling noise on the left rear of my A4 when driving slowly (under 60 km/h) over potholes and uneven surfaces. I inspected the corresponding side and noticed that the wheel has some vertical play. I tried adjusting the bearing clearance as a test, but it didn't make any difference."
Since the rear brakes will also need to be replaced soon, I plan to replace both the rear brakes and wheel bearings in the next 10,000 km.
My question is now, can I wait a bit longer with this change, or should I address it as soon as possible? I've been driving with the worn-out tires for about 10,000 kilometers.
Translated on 18-08-2026, 10:25.
Herr Antje
Post30-03-2006, 14:22    Subject: Rear Axle Noise Audi A4 B5 Quote
is it really the wheel bearing? icon_eek.gif If so, we'll replace the bearing at the same time. You can have it done regardless of the brake (even if you continue driving with the old brake).
Normally, a wheel with a damaged wheel bearing will have play and make noise in all directions. I usually associate knocking sounds with the axle suspension, shock absorbers, or the strut mount/plate of the shock absorbers.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 18-08-2026, 10:27.
bastion
Post30-03-2006, 14:30    Subject: Rear Axle Noise Audi A4 B5 Quote
Yes, I lifted the rear of the car. It really can't be anything else. There's only a faint scraping sound coming from the pads, no other noises while it's moving.
Okay, the game isn't just vertical; it also has a horizontal element, but only to a minimal extent.
The wheel bearings are partially pressed into the disc, and I don't want to remove them from the disc again, as that could potentially damage the bearing.
Translated on 18-08-2026, 10:28.
Herr Antje
Post30-03-2006, 15:38    Subject: Rear Axle Noise Audi A4 B5 Quote
I wouldn't drive more than 10,000 km with a broken bearing. The condition of the rear brakes will determine what you do next. No one can tell you exactly how far you can drive like that. Eventually, you might also need a wheel hub (what is that called in German?). Definitely that part in the middle of the bearing.
Wasn't this changed at some point with the A4 B5? I hate this simple design. In my GIII, the bearings are also practically pressed into the glass. There are better solutions out there...
Aktuell:
Translated on 18-08-2026, 10:29.
bastion
Post30-03-2006, 15:46    Subject: Rear Axle Noise Audi A4 B5 Quote
I have an Audi A4, manufactured in 1996, so it's one of the first models.
Translated on 18-08-2026, 10:30.
bastion
Post08-04-2006, 14:46    Subject: Rear Axle Noise Audi A4 B5 Quote
Okay, for those who are interested. The rattling noise wasn't coming from the wheel bearing. It was rust on the contact surface between the rim and the hub.
BM
Avatar-BM
Post08-04-2006, 18:02    Subject: Rear Axle Noise Audi A4 B5 Quote
The rattling noise wasn't coming from the wheel bearing. It was the rust on the contact surface between the rim and the hub.
I've never heard of anything like that before. I would rather suspect that the wheel wasn't properly tightened in the first place. Let's see if the noise reappears.
3B5 AJM
Translated on 18-08-2026, 10:31.
Herr Antje
Post08-04-2006, 22:33    Subject: Rear Axle Noise Audi A4 B5 Quote
bastion wrote:
So, for those who are interested. The rattling noise didn't come from the wheel bearing. It was the rust on the contact surface between the rim and the hub.
You mentioned something about play. If there's play in the hub, then the wheel bolts probably weren't tightened enough, right?
Aktuell:
Translated on 18-08-2026, 10:32.
bastion
Post09-04-2006, 1:00    Subject: Rear Axle Noise Audi A4 B5 Quote
Yes, it's back again. It disappeared for about 10 km after the tire change... Well, it would have been boring if it had been something cheap...
BM
Avatar-BM
Post09-04-2006, 21:48    Subject: Rear Axle Noise Audi A4 B5 Quote
Yes, it is back again.
Well, I already suspected that. Now, it's necessary to check all the mounting points (rubber bushings) of the rear axle rubber components and shock absorbers for wear.
For example, in the case of a Volkswagen Golf 3, there is a 99% chance that the rear axle bushings are causing such a rattling noise.
3B5 AJM
Translated on 18-08-2026, 10:33.
bastion
Post11-04-2006, 7:45    Subject: Rear Axle Noise Audi A4 B5 Quote
It's the wheel bearings. The suspension and everything else is fine.
Translated on 18-08-2026, 10:34.
No new posts Phaeton Noise: Front Axle 3D2 Diagnosis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cracking noise from rear axle, Audi A6 4F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J, Clicking, Squeaking at the rear axle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Front Axle Noise: Causes & Solutions Transmission, Chassis, Body & Interior
No new posts Car Suspension Noise When Starting Transmission, Chassis, Body & Interior
No new posts Steering Noise: Causes & How to Fix It Transmission, Chassis, Body & Interior
No new posts Poltern von der VA beim Bremsen in Kurven Transmission, Chassis, Body & Interior
