heini1 Guest
25-04-2004, 11:27 Subject: VAG-COM: Old Versions & Downloads |
Hello everyone,
Is there still any VAG-COM software version that uses optocouplers?
I built a simple modem that works with OK's, and I don't want to build another one again.
I would also like to extract only the error block.
If anyone can help or has a trial version, I would appreciate it!
Bye.
Heini.
Translated on 19-08-2026, 12:07.
WarLord Guest
25-04-2004, 12:46 Subject: VAG-COM: Old Versions & Downloads |
Why shouldn't the new ones work with it?
Best regards, WarLord.
Translated on 19-08-2026, 12:08.
heini1 Guest
25-04-2004, 13:54 Subject: VAG-COM: Old Versions & Downloads |
Well, it says on the VAG-COM website that the new version available for download doesn't work with OK.
Or am I misunderstanding something?
Translated on 19-08-2026, 12:09.
Gremlin Guest
25-04-2004, 14:29 Subject: VAG-COM: Old Versions & Downloads |
No, unfortunately, that's the way it is.
The latest versions of VAG-COM are no longer compatible with the simple interfaces, which I think is completely ridiculous.
CU Gremlin.
WarLord Guest
25-04-2004, 14:36 Subject: VAG-COM: Old Versions & Downloads |
'Have the timings been changed? Which version of VAG-COM is this?'
Translated on 19-08-2026, 12:10.
heini1 Guest
25-04-2004, 14:43 Subject: VAG-COM: Old Versions & Downloads |
The one that's currently available on the VAG COM homepage is no longer working with 'OK' confirmations.
But maybe someone still has an older version that we could share via email?
My email is:
heini_der_erste at hotmail.com
In the post, you can't see the underscores, so it looks like 'heini' underlined 'der,' then underlined 'unterstrich,' then 'erster,' etc.
Thank you.
Heini.
Translated on 19-08-2026, 12:11.
Uwe@Ross-Tech Guest
25-04-2004, 20:13 Subject: VAG-COM: Old Versions & Downloads |
Incorrect. Release 311 from our download page still works with Optos.
The 4xx beta versions are no longer compatible with Optos. However, it doesn't really matter because the new features in the 4xx series primarily relate to CAN diagnostics, which wouldn't work anyway with a custom-built interface.
-Uwe-
Translated on 19-08-2026, 12:12.
WarLord Guest
25-04-2004, 20:26 Subject: VAG-COM: Old Versions & Downloads |
@heini1
Okay, I just emailed you the 3.11 Release 2. Hopefully, you can find it useful.
Translated on 19-08-2026, 12:13.
heini1 Guest
28-04-2004, 14:29 Subject: VAG-COM: Old Versions & Downloads |
Okay, I finally got my small DIY circuit working!
'Not much comes from the control unit in my T4 anyway, but what does come is enough for my purposes!'
Once again, many thanks to the two generous donors of the software  .
Bye.
Heini.
wuzel80 Guest
14-04-2006, 16:04 Subject: VAG-COM: Old Versions & Downloads |
I also want to buy an OBD cable. I saw one on elv.de that has a CAN connection. I have VAG COM 3.11 at home (just downloaded it from Ross-tech). Does anyone know if it works with that? Because with VAG, I can only select COM ports, and I want the adapter cable to be a USB version since my laptop only has USB ports.
Does anyone have any tips for me?
Thank you all very much in advance!
Is the VAG-COM 3.11 software available in German?
[Edit Admin: Advertising links removed. Are you also asking at Elektro Meyer what the color TV is like that's available at Elektro Müller, and distributing flyers for him in his store? There are people like that...  ]
Translated on 19-08-2026, 12:15.
Rudi Guest
14-04-2006, 17:00 Subject: VAG-COM: Old Versions & Downloads |
According to the description on the ELV website, this device is likely compatible with VAG-COM up to version 311.
(Did they drill a hole in the ELM so that it could also be used as a bare...)
Implementing a USB/232 to K/L-line interface.
I suspect that this component will integrate into the system using a virtual COM driver.
So, you connect it via USB, but it exposes a virtual COM port.
If you're trying to interface with VAG vehicles using CAN, it won't be very helpful because of all the...
certain interesting functions (such as measurement data blocks) were not yet available with the 311.
The truly sensible solution is the one presented here.
http://shop.dieselschrauber.de/product_info.php/products_id/46
It's also worth considering for hobby users, especially if they need CAN functionality.
Which diagnostic system for which car?
http://shop.dieselschrauber.de/VCDS-Fahrzeugliste.pdf
Rudi
Translated on 19-08-2026, 12:17.
