Graphics Card Issues: Troubleshooting Guide
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Holger247
Post25-04-2006, 8:49    Subject: Graphics Card Issues: Troubleshooting Guide Quote
I installed a new GRA (Gas Return Assist) system with a new lever in my Volkswagen Golf IV, but it's not working exactly as expected.
Generally, I can activate the cruise control using the SET/ - button to have it maintain a certain speed. When I press the + (Res) button, it will also accelerate, but not in increments of 1.5 or 3 km/h, rather continuously (until I press the - button again).
Both brake switches and the clutch switch are okay according to the log.
If I look at group 6, field 3, then at least the assignment of switches to bits is correct.
OFF 000000
ON 000011, but sometimes also 001011.
Hold down the ON and SET buttons simultaneously: 000111.
Pressing the "ON" and "+/RES" buttons once results in "001011". This value remains until either the brake is applied or the "-" button is pressed, although pressing "-" only reduces the speed by 1.5 km/h.
The problem lies with the function of "+". While bit 3 can be clearly activated using "+", it's unclear how long the value needs to remain there. It seems possible that the value is only supposed to stay there as long as the button is pressed. However, since the value remains, the car accelerates continuously instead of just becoming 1.5 or 3 km/h faster.
I consider a wiring error unlikely, as the correct bits are essentially being transmitted.
Since I've read about faulty switches in several previous posts, I now suspect the switch itself (it might not be returning to its original position properly). Before I take everything apart again, I wanted to get your opinions on this.
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 19-08-2026, 4:29.
Post25-04-2006, 9:20    Subject: Graphics Card Issues: Troubleshooting Guide Quote
Hi.
"Why don't you measure the switch with a simple multimeter? You should immediately hear the continuity beeper if there's a problem."
Translated on 19-08-2026, 4:32.
Post25-04-2006, 12:03    Subject: Graphics Card Issues: Troubleshooting Guide Quote
Hi Holger,
If the bit remains stuck in the control unit when you tap it, there is a high probability that the switch inside the lever is faulty.
Unfortunately, my original GRA lever also had a rather short lifespan... it seems to be mechanically quite cheaply made.
Translated on 19-08-2026, 4:33.
Holger247
Post27-04-2006, 9:31    Subject: Graphics Card Issues: Troubleshooting Guide Quote
Thank you for the answers.
The multimeter test revealed that the "+"/"RES" button does not release after being pressed – it remains engaged until the "-"/"SET" button is pressed.
Now I know why the switches were on special offer at VW - probably a batch with defects icon_wink.gif.
You can also check this with a built-in switch (at least in the Golf IV) by simply opening the upper steering column cover. However, it's helpful to use a cable with a 10-pin connector (e.g., an old computer cable) to extend the connection.
Here's the configuration I tested:
(therefore, disconnect the power supply connection for SW/BL (T10s/6)).
blue (T10s/2): "+" / "RES"
red/yellow (T10s/3): "-" / "SET"
white (T10s/5): "ON + ACTIVE" (i.e., opens when switched from the ON position to the OFF position).
sw/gn (T10s/4) (T10s/7): "ON"
bl/sw (T10s/6): Power supply, Class 15.
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 19-08-2026, 4:35.
Post27-04-2006, 9:42    Subject: Graphics Card Issues: Troubleshooting Guide Quote
Okay, please provide the German text you would like me to translate into English.
and successfully diagnosed remotely again icon_smile.gif.
Then, Volkswagen would have to completely replace it and put a new one on the table, which you would then have to "install" by pressing buttons repeatedly and checking the shifting behavior with a multimeter.
Effort:
low cost... a real pain... lots of time.
Translated on 19-08-2026, 4:37.
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic 01N with AFN Engine - Problem with the Gearbox ... General Tips
No new posts Problem behoben,neues Problem Diesel Engine Technology
No new posts Problem mit WFS On-Board Diagnostics (OBD)
No new posts 2.0 TDI BPW A4 Problem mit DPF Diesel Engine Technology
No new posts VTG Issue: Troubleshooting and Solutions Diesel Engine Technology
