Opel Corsa: Blinking Fast - What to Do?
wollif
Post02-05-2006, 7:27    Subject: Opel Corsa: Blinking Fast - What to Do? Quote
I'm having a problem with an Opel Corsa, manufactured in 2002:
When the right turn signal is activated, it blinks at twice the normal frequency.
However, none of the light bulbs are defective (2 front, 2 side, 2 rear)!
The hazard lights are working perfectly.
What could be the reason for that?
I'm sorry, I don't understand. Can you please rephrase your request?
Translated on 23-09-2026, 10:15.
Post02-05-2006, 8:58    Subject: Opel Corsa: Blinking Fast - What to Do? Quote
Are the headlights on the right side of the car using bulbs with only half the power? Do all the lights on the right side also blink?
Translated on 23-09-2026, 10:16.
wollif
Post02-05-2006, 10:27    Subject: Opel Corsa: Blinking Fast - What to Do? Quote
Yes, all the indicator lights are working, including the warning lights. I haven't changed anything, no bulbs or anything like that. It happened suddenly, now the three indicators on the right side are blinking at double the frequency.
Post02-05-2006, 10:39    Subject: Opel Corsa: Blinking Fast - What to Do? Quote
Does the flasher relay have separate contacts for the right and left sides?
Then, just as a test, try replacing the relay, because the problem might be with it.
For the Golf 3, the relay "doesn't know" about the sides, and this error pattern cannot be caused by the relay.
Translated on 23-09-2026, 10:17.
tdi-schrauber
Post03-05-2006, 17:14    Subject: Opel Corsa: Double turn signal frequency Quote
Hello!
e.g., a faulty turn signal switch or connector (contact resistance too high).
BYE
TDI mechanics.
Translated on 23-09-2026, 10:18.
wollif
Post05-05-2006, 11:59    Subject: Opel Corsa: Blinking Fast - What to Do? Quote
The problem has been resolved.
1. Turn on the hazard lights.
2. Activate the right/left turn signal.
3. Turn off the hazard lights.
-> The turn signal is working normally again!
Don't ask me why.
Here's what I found out: The Corsa actually has separate relays for the right and left turn signals. However, these relays are not located in the fuse box, but in another housing in the upper right corner of the engine compartment. The control unit is probably also located in this housing. This box is screwed on with Torx screws and is not designed to be easily opened.
Translated on 23-09-2026, 10:19.
No new posts Opel Corsa C Start Problems: 1.3 CDTI Fix Diesel Engine Technology
No new posts Smallest Battery for Opel Corsa A: Find Yours! Transmission, Chassis, Body & Interior
No new posts VAGCOM for Opel Corsa B: Diagnostics & Repair On-Board Diagnostics (OBD)
No new posts OPEL Corsa C: AGR Problems & Solutions Diesel Engine Technology
