Quote: |
| I will check the cylinder head bolts this week, and if necessary, tighten them if it really turns out to be the cause... |
This is just a temporary fix and not a repair!
Quote: |
| Don't come complaining later if things get completely out of control, okay? |
I completely agree. If the cylinder head gasket is leaking, it should be repaired as quickly as possible, rather than experimenting with things that won't help and will ultimately cause more damage and expense.
Since my car had already experienced a head gasket/cylinder head damage at 63,000 km under the previous owner (covered by warranty from VAG), and the second head gasket also only lasted 76,000 km, I did some investigating into the cause back then.
During the process, I also checked to ensure that the head was still securely fastened and therefore opted for ARL screws to reduce vibration-induced seal gaps in the long term.
See the technical article by ElringKlinger regarding the relationship between sealing gap oscillation and clamping force:
http://www.ekmt.de/fachartikel/0101_mtz.html
