ESP Shaft: 0.1mm Play - Replacement?
Nebelwerfer_TDI
Post23-05-2006, 12:48    Subject: ESP Shaft: 0.1mm Play - Replacement? Quote
Hello!
I just had a T4 with a 1X engine in for a major service, including a replacement of the timing belt. After removing the timing belt, I noticed that the shaft of the ESP (electric steering pump) has a minimal amount of radial play (in the tenth of a millimeter range). The pump is estimated to have a total mileage of around 300,000 km (estimated, as the odometer has likely been tampered with).
What do you think I should do, leave the pump as it is, or replace the pump/bearing? I have a spare self-priming/rotary pump lying around that I could install. It will probably leak a bit since it's a turbo pump.
By the way: The 'Killerschraube' bolt has the marking 8.8 icon_eek.gif icon_eek.gif icon_eek.gif (stiff 10.9, like on the AAZ) -> it will be replaced with a 12.7 bolt.
I'm looking forward to your answers!
Best regards, Nebelwerfer.
Translated on 06-10-2026, 8:21.
No new posts Rear Engine Mount for VW T6 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Painting Terms: A Comprehensive Glossary Technical Articles
No new posts Audi A2 to A6 goodwill policy, body section Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climate compressor, shaft blocked Transmission, Chassis, Body & Interior
No new posts Turbine Shaft Bearing: Design & Application Diesel Engine Technology
No new posts ESP Wave Alignment: Cylinder 1 Diesel Engine Technology
No new posts Drive Shaft Games: Fun & Education Transmission, Chassis, Body & Interior
