AFB Compression: Explained and Optimized
flaufer
Post11-05-2006, 16:36    Subject: AFB Compression: Explained and Optimized Quote
Hey everyone,
During the breakdown repair of my vehicle (which included replacing the fuel injection pump and fuel pump, with an engine having approximately 160,000 km mileage and a vehicle mileage of 290,000 km, manufactured in 1999, with a new engine installed around May 2002), a compression test was also performed.
I don't have the documents readily available right now, but I remember that the compression was approximately 25 (I don't recall the unit) for all cylinders, with a variation of about plus or minus 3. However, the compression for cylinder #1 was only about 17.
The engine is actually running normally (very loud, but it has been like that for 7 years), and it's pulling well.
Since I had a lot of trouble with the first engine due to worn camshafts, I wanted to finally address that issue.
What can I read from such compression measurements? icon_wink.gif In my old days of tinkering with Ford engines, it usually ended up being either a head gasket issue or needing to tighten the spark plugs... } but those were also somewhat simpler engines.
Felix.
Translated on 08-10-2026, 6:11.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post11-05-2006, 20:53    Subject: AFB Compression: Explained and Optimized Quote
I assume that the engine was cold during this measurement.
Therefore, it is not necessarily very informative.
Do it when it's warm. It's unlikely anyone will have it at pressures below 20 bar.
B.Eng (FH) u. KFZ Meister
Translated on 08-10-2026, 6:13.
Devilseye503
Post25-05-2006, 14:25    Subject: AFB Compression: Explained and Optimized Quote
AFN:
new: 25...31 bar overpressure.
Wear limit: 19 bar overpressure.
Allowable pressure difference between all cylinders: 5 bar.
No new posts TDI 2.5: Compression Problems & Solutions Diesel Engine Technology
No new posts AHF: Poor Compression - Causes & Solutions Diesel Engine Technology
No new posts AKE V6 TDI: Low Compression Issues Diesel Engine Technology
No new posts A4 B6 2.5 TDI AKE Air Filter Diesel Engine Technology
