'Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein.'
Hello everyone,
I have a question.
I would like to read the CAN bus data from a 2003 1.9 TDI vehicle with an ASV engine, without ESP or automatic transmission.
Unfortunately, I couldn't detect any activity on the bus when I accessed it.
Can I activate the CAN bus from the control panel, gateway, and MSG modules using VAG-COM coding?
Can I switch to 'Automatic' mode without the MSG going into emergency mode, and can I log the CAN communication to the (non-existent) automatic transmission?
With ESP and automatic transmission, the CAN bus is active!
If I make a tuning change that can be switched via MSG coding, and a physical switch on the CAN bus is also 'open,' how does the control unit behave?
I am grateful for any assistance.
