VAG-COM - Motor STG - Block 018 | Posts 16+
Go to page: Previous  1, 2
blizzard
Post01-06-2006, 8:25    Subject: Quote
aaaaaaaaa
It would be nice if you could then be so kind and post something here sometimes icon_smile.gif.
Thank you in advance.
Best regards, Blizzard.
G4 TDI PD 74kw AXR
5tkm 1xAGR Ventil (Geräusche)
144Tkm 1xEUH Getriebe + Kupplung
2x POPO Heizung geflickt
155TKM PDE Kabelsatz (ruckeln)
240TKM Wasserpumpe hin
244TKM MFA selbst rep.
305TKM LL Druckschlauch (Nasen weg
320TKM GLÜHKERZEN erneuert
Translated on 13-08-2026, 20:03.
boki2006
Post04-06-2006, 11:08    Subject: Quote
Here are the status codes related to the BIP regulation that I was able to find:
0: OK.
2: BIP control after initialization; BIP acquisition remains active.
4: No measurement of brake input pressure (e.g., due to a very short injection time), but the brake input pressure measurement remains active.
6: Error detected during startup or KTF (Key Transfer Function) failure -> BIP control and BIP acquisition remain active.
7: Bi-directional control due to high speed.
8: Battery Isolation Protection (BIP) activated due to low battery voltage.
10: Battery protection system (BPS) activated due to excessively high battery voltage, or a fault in the battery voltage measurement.
14: Magnetic valve fault detected (e.g., short circuit) -> Emergency Stop control.
15: Errors detected in GDP recording -> GDP control.
Klaus.
Translated on 13-08-2026, 20:05.
blizzard
Post05-06-2006, 10:52    Subject: Quote
"Oh, thank you."
Does KTF stand for "cooling temperature sensor"?
If that's the case, then it makes sense that I had a 6 at the beginning.
Since the G62 module was malfunctioning, it has now been replaced.
G4 TDI PD 74kw AXR
Translated on 13-08-2026, 20:07.
boki2006
Post05-06-2006, 19:57    Subject: Quote
KTF stands for KraftstofftemperaturfĂźhler, which translates to fuel temperature sensor.
As I understand it, status 6 only occurs during startup. At this point, the battery voltage may be dropping or there might be air trapped in the PD elements, which prevents the BIP (Battery Impedance Protection) system from functioning correctly. Therefore, during this phase, the BIP is only activated and any BIP errors are suppressed.
Translated on 13-08-2026, 20:08.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts EA288 2L CR Engine Block Diesel Engine Technology
No new posts AAZ block, JX head, is it possible? Diesel Engine Technology
No new posts 1Z Engine: Horsepower & Performance Specs Diesel Engine Technology
No new posts Measurement Block 9 Field 3 Diesel Engine Technology
