suggermilk wrote: |
| The resistance is reduced by approximately half due to the diodes. I understand that DAAS is clear!! |
"Wrong, sorry, without basic knowledge of electronics, I'm just talking nonsense."
Take a look online at the different types of diodes available. Also, examine the current-voltage (U/I) characteristic curve of a diode; this will help you understand the purpose, especially in conjunction with the "idle problem" when using active 10C tuning. Why are two diodes used? The regulator is subjected to a sinusoidal current.
