Diagnostic options for Smart CDI?
dieselcruiser
Post12-06-2006, 14:32    Subject: Diagnostic options for Smart CDI? Quote
What options are there for reading the error memory of a Smart ForTwo CDI, manufactured in 2001, yourself? Is there any software comparable to VAG-COM available, and also a suitable adapter that can be purchased? I haven't been able to find anything on eBay or anywhere else online.
Translated on 20-07-2026, 2:22.
denni
Post12-06-2006, 20:42    Subject: Diagnostic options for Smart CDI? Quote
Maybe this will help you.
http://www.smart-forum.de/modules.php?op=modload&name=Forum&file=viewtopic&topic=42014&forum=19
Translated on 20-07-2026, 2:23.
Post12-06-2006, 20:54    Subject: Diagnostic options for Smart CDI? Quote
For current Smart ForTwo CDI models (from 2003 onwards), VAG-COM can also be used.
However, things are likely to be worse with the 2001 model, as the engine control unit probably doesn't yet support the OBD2 protocol. This means that all other tools based on the OBD2 protocol will also not work.
dieselcruiser
Post13-06-2006, 11:12    Subject: Diagnostic options for Smart CDI? Quote
Thank you for the responses. I also received a rejection from obd-2.de regarding a diesel vehicle from 2001.
Translated on 20-07-2026, 2:24.
No new posts Smart Fortwo: Gear won't shift from Neutral to Drive General Tips
No new posts Experiences with Smart CDI - 45 PS & 54 PS; ECU Diesel Engine Technology
No new posts Smart parking only Upload
No new posts VAG-COM: Does it work on other cars? (Smart) On-Board Diagnostics (OBD)
