With the right tool, it's easy. However, the press should be quite powerful when dealing with the 82-size bearings.
Sequence:
Hub.
Inner ring of hub.
Store from the inside out, without a retaining ring.
Press the bearing in, paying attention to the diameter of the inner ring.
Press the hub into place. Gruß Christian
Translated on 04-10-2026, 8:39.
