legolas09 Guest
12-07-2006, 8:37 Subject: PIN Assignment Comfort Control Unit |
I installed the 1C0 959 799F comfort control module. This module is integrated into the comfort CAN bus of the Passat and transmits data to the instrument cluster (IC) regarding open doors, etc.
Menem Leon is missing the wiring from connector 1C0 to connector KI (green connector, pins 8/9).
I would now like to implement this myself and try to feed the data about open doors, etc. via CAN bus.
Does anyone know where I can 'tap into' the lines on the 1C0?
Translated on 26-10-2026, 7:55.
12-07-2006, 19:24 Subject: PIN Assignment Comfort Control Unit |
T29/8 = CAN Comfort High.
T29/27 = CAN-KOmfort Low.
Translated on 26-10-2026, 7:56.
legolas09 Guest
13-07-2006, 10:15 Subject: PIN Assignment Comfort Control Unit |
Thank you  .
BUT I just found something else... so what's the right fit for me now?
'1C0 959 799F Comfort System Control Unit for a New Beetle 02-'.
J393
T23 pin 9 = CAN-High.
T23 pin 6 = CAN-Low.
Translated on 26-10-2026, 7:57.
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2405 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
13-07-2006, 11:52 Subject: PIN Assignment Comfort Control Unit |
Just check if you have a 23-pin or a 29-pin connector. Then you can answer the question yourself!
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Profile PM Garage |
13-07-2006, 15:32 Subject: PIN Assignment Comfort Control Unit |
The central control units with 23 pins are for vehicles WITHOUT electric folding mirrors (eFH), while the comfort control units with 29 pins are for vehicles WITH electric folding mirrors (eFH).
So, if you read the SLP correctly, you can see that.
Translated on 26-10-2026, 7:58.
legolas09 Guest
13-07-2006, 15:42 Subject: PIN Assignment Comfort Control Unit |
 all clear, thank you... therefore, should I get a T29  ?
13-07-2006, 15:48 Subject: PIN Assignment Comfort Control Unit |
Yep, that was the reason why I posted that above.
Translated on 26-10-2026, 7:59.
legolas09 Guest
18-07-2006, 10:22 Subject: PIN Assignment Comfort Control Unit |
Okay, I've now connected it, and it's working great... but I only had the T23 connector  .
| Description: |
| File size: |
473.54 KB |
| Viewed: |
1330 times |
