Jochen_145 wrote: |
| The reason the Leon has a "separate Climatronic" system is because the G4's Climatronic is connected to the Comfort-CAN. |
It's simply because the design, and therefore the fit, of the front is different.
Jochen_145 wrote: |
| Therefore, I don't believe that the label file from G4 is compatible. |
"No offense, but the correct saying is 'Knowledge is power,' not 'Belief is power.'
Basically, the 1J/3B label is suitable, although the MWB codes 009/010/011/013 are not yet covered. Assuming you (Martin) are using an up-to-date VAG-COM version, please proceed as follows:
VAG-COM > Applications > Control Unit Image.
Address: 08
Function: Measurement data blocks.
Format: Label template.
Start
After that, you will find the file 08-1M0-820-043-C.PLB in the directory /VAG-COM/Logs/, and you should then send it to me via email.
