HEX CAN Interface: Is it normal to be hot?
Post26-07-2006, 7:03    Subject: HEX CAN Interface: Is it normal to be hot? Quote
After about 20 minutes of operation, my new interface from Rainer's shop is "warm to the touch" around the LED at the top. When I unplugged it, I noticed it was quite warm, although the heat wasn't painful.
I estimate the surface temperature to be roughly 20K above the ambient temperature.
If I imagine the temperatures that must be present behind the insulating plastic layer inside the plug in order to transport so much energy outwards, I find it somewhat concerning icon_eek.gif.
Do all interfaces do this, and is it harmless?
So far, mine seems to be working normally.
Translated on 31-08-2026, 8:41.
Nebelwerfer_TDI
Post26-07-2006, 8:25    Subject: HEX CAN Interface: Is it normal to be hot? Quote
My HEX USB interface also gets quite warm, and a temperature 20K above the ambient temperature is not uncommon. Even my EDC 15 flasher gets noticeably warmer than the surroundings, even though it's only in operation for a short time.
When I imagine the temperatures that must exist behind the insulating plastic layer inside the plug, in order to transport so much energy outwards, it seems a bit concerning to me .
Think about how warm a laptop power adapter gets, and your worries will quickly disappear icon_wink.gif.
Translated on 31-08-2026, 8:42.
Ross-Tech-Support
Post26-07-2006, 9:02    Subject: HEX CAN Interface: Is it normal to be hot? Quote
In the case of HEX interfaces, this is absolutely safe. With many (e.g., Ross-Tech and their distributors), interfaces are often connected to test benches or similar setups almost around the clock, and no problems arise. Of course, some heat generation is normal, as this involves electronics.
Some might say that there are interfaces that cannot handle this and will become significantly hotter, but those are not from Ross-Tech and do not have names like HEX/KEY/µCAN. icon_lol.gif
Translated on 31-08-2026, 8:43.
Malte1408
Post26-07-2006, 10:32    Subject: HEX CAN Interface: Is it normal to be hot? Quote
My Hex+CAN also gets quite hot, especially in this weather. It can easily reach 25K above ambient temperature. After longer measurement runs, it becomes quite unpleasant to touch, with a surface temperature of around 50°C.
How much power does it actually draw from the on-board electrical system? icon_twisted.gif
Malte.
Translated on 31-08-2026, 8:44.
Post26-07-2006, 10:53    Subject: HEX CAN Interface: Is it normal to be hot? Quote
Don't worry. I'm getting the same and similar temperatures. But it won't get much warmer; I once drove it almost 500km with it connected to a laptop.
Translated on 31-08-2026, 8:45.
Post26-07-2006, 11:22    Subject: HEX CAN Interface: Is it normal to be hot? Quote
Sebastian@OpenOBD wrote:
Since this naturally involves electronics, a certain amount of heat generation is normal.
Sure, but since the interface essentially only manages "lossless" signals (rather than transmitting useful energy), the perceived power loss initially seemed a bit too high to me.
But now it's clear, thank you for the answers icon_smile.gif.
Translated on 31-08-2026, 8:46.
No new posts Oil in Coolant: Is it Normal? Diesel Engine Technology
No new posts LLT Normal: Is It Normal? Upload
No new posts Only 8 volts on the N75, is that normal??? Diesel Engine Technology
No new posts GRA Behavior in ASZ (96 kW PD) - What's Normal? Transmission, Chassis, Body & Interior
