Document Passat, Model Year 2000, Brakes Stuck (Solution)
Michael II
Post05-12-2002, 9:19    Subject: Document Passat, Model Year 2000, Brakes Stuck Quote
Passat, model year 2000: Brakes stuck, brakes overheating.
Affected vehicle identification numbers:
Up to 12.99; incl. VAT. Number: 3BYE 240 844
Until 4:00 AM; Background. Number: 3BYE 394 536
Cause:
Production-related tolerance ranges.
Solution:
The brake booster must be connected without any tension.
- Loosen the screw on the bearing bracket.
- Loosen the screws that connect the bearing bracket to the master cylinder and the brake booster.
- Move the brake booster back and forth to allow for stress-free installation.
- First, tighten the fittings, and then tighten the screw on the bearing bracket, being sure to observe the specified torque.
- Then, adjust the brake light switch.
Tschüss
Michael II
Ratings - Document Passat, Model Year 2000, Brakes Stuck
No new posts Document: Passat, Model Year 2000, Window Seal is Raised/... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 2000: Sun Visor Light Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 2000: Rear Brake Noise Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 brake problem - Please help! Transmission, Chassis, Body & Interior
No new posts Bremse Passat Neu On-Board Diagnostics (OBD)
No new posts Electric brake for Passat / A6 / A8 On-Board Diagnostics (OBD)
No new posts Passat 3bg 1.9 TDI PD / Brake, front left, under pressure Transmission, Chassis, Body & Interior
