Software Version: MSG Part Number Lookup
benje2
Post01-08-2006, 15:22    Subject: Software Version: MSG Part Number Lookup Quote
Are all MSG (038906019) hardware components identical, or to put it another way, what do the last two digits in the part number signify? I have a 038906019JQ. Can I flash the same software onto an equivalent part?
Translated on 03-08-2026, 6:49.
Rudi
Post06-08-2006, 20:48    Subject: Software Version: MSG Part Number Lookup Quote
Not all 019xx numbers are the same!
Flashing can work, but it can also disable the ECU (Engine Control Unit).
(then there's only one thing left to do: use a soldering iron).
Rudi
Translated on 03-08-2026, 6:50.
benje2
Post06-08-2006, 21:08    Subject: Software Version: MSG Part Number Lookup Quote
I'll probably have to spend a few euros. Well, I'll let you know which versions are compatible.
Translated on 03-08-2026, 6:51.
Rudi
dieselschrauber likes this.
Post06-08-2006, 21:19    Subject: Software Version: MSG Part Number Lookup Quote
Even if the flashing process is successful, it doesn't necessarily mean that the engine control unit (ECU) will work without problems.
it works in the car that matches the dataset.
If you wanted to create an accurate overview, you would probably need to include the euros.
No new posts Explanation of the VAG part number Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Software Version 038 906 012 AT - Change Diesel Engine Technology
No new posts Audi A3 Software Update: Check & Download On-Board Diagnostics (OBD)
No new posts ECU Software Version: Read & Check Now On-Board Diagnostics (OBD)
No new posts MSG 038 Software: Update Available? On-Board Diagnostics (OBD)
