Mütze Guest
11-08-2006, 12:46 Subject: Throttle Valve Error: "Lower Limit" (AKL) |
'I'm having an idle problem with my A3. When the engine starts, the idle speed is around 830 RPM. However, as soon as I briefly press the accelerator, the idle settles at 1000-1200 RPM, and it's quite unstable (fluctuating RPM). The error code in the diagnostic memory is 00533: 'Idle speed control, lower limit exceeded.' This error only appears after pressing the accelerator; there are no errors when starting or idling. Interestingly, when the air conditioning/ventilation is turned on, the RPM drops back towards 800. I've already removed and cleaned the throttle valve. I've also checked for vacuum leaks using brake cleaner... '
The initial setup is running without any problems. Do you perhaps have any ideas?
Thank you for your help.
Hat.
Translated on 23-10-2026, 2:06.
Herr Antje Schrauber
Joined: 01/18/2006 Posts: 1547 Karma: +7 / -0 Location: Nahe Tübingen
11-08-2006, 13:49 Subject: Throttle Valve Error: "Lower Limit" (AKL) |
Maybe you should check out an A3 forum and do some reading... Probably a 1.6, right?
Assumption:
Throttle body, most likely. Are the temperature and lambda values within the normal range? Is the throttle position sensor reading plausible? Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 23-10-2026, 2:07.
Mütze Guest
11-08-2006, 14:15 Subject: Throttle Valve Error: "Lower Limit" (AKL) |
Yes, it's a 1.6L engine with 101 horsepower, engine code AKL. The temperature and lambda values are within the normal range, as indicated by VAGCOM.
Hat.
Translated on 23-10-2026, 2:08.
bloesch Profi-Schrauber
Joined: 03/18/2005 Posts: 622 Karma: +16 / -0 Location: FL
11-08-2006, 16:17 Subject: Throttle Valve Error: "Lower Limit" (AKL) |
hi.
"If you've cleaned the throttle body, you should clear the learned values of the engine control unit (ECU) before performing the adaptation procedure; otherwise, the whole process might be useless (based on experience)."
"On the 1.6 models (at least the A3), the lambda sensors regularly fail. My friend needs a new one for every inspection... but you said yours are okay, so it doesn't matter."
Okay, so delete the learned values and retrain the model.
Translated on 23-10-2026, 2:09.
11-08-2006, 22:06 Subject: Throttle Valve Error: "Lower Limit" (AKL) |
Schraubi-Schlumpf wrote: | hi.
In the 1.6 models (at least in the A3), the lambda sensors regularly fail. |
I'm familiar with the throttle body issues. They're apparently also prone to problems. That's also why I suggested the 1.6 [engine]. Aktuell:
Translated on 23-10-2026, 2:10.
11-08-2006, 22:40 Subject: Throttle Valve Error: "Lower Limit" (AKL) |
Quote: | | I'm familiar with the issue of throttle bodies. They are apparently also prone to problems. |
I also thought that initially... however, if you delete the learning values before starting the learning process, suddenly there are significantly fewer throttle bodies that are defective  .
Mütze Guest
13-08-2006, 20:36 Subject: Throttle Valve Error: "Lower Limit" (AKL) |
Which learning values should be deleted, and where? It would be helpful if you could provide more details.
Thank you very much.
Hat.
Translated on 23-10-2026, 2:11.
13-08-2006, 20:59 Subject: Throttle Valve Error: "Lower Limit" (AKL) |
Oh... let me think (I only know the original VAG tester).
either.
01 msg
- 04 default settings
-- 00 delete learnable parameters.
or
01 msg
- 10 customizations
--00 lw delete
I believe the former.
Possible symptoms for diagnostic trouble code 00533:
- high fuel consumption
Possible causes:
- Vacuum leak between the mass airflow sensor (MAF) and the engine.
- faulty injector(s)
- fuel pressure regulation faulty.
- faulty throttle valve
- air filter is dirty.
possible solutions:
- Throttle valve basic adjustment.
- Check hoses/intake manifold for leaks (e.g., using brake cleaner).
- Check the air filter.
- Check fuel pressure / fuel pressure regulator.
- Check the EGR valve.
- check the injector(s)
Translated on 23-10-2026, 2:13.
