DZR - Should you wait until 2000, or sooner???
SeatLeon
Post07-12-2002, 7:47    Subject: DZR - Should you wait until 2000, or sooner??? Quote
I wanted to use a flow rate calculator to calculate my performance. Do I need to drive at 2000 RPM for a while first, and then accelerate with a 'moment of silence,' or can I give it gas earlier and start timing from 2000 RPM?
tim27
Post07-12-2002, 10:03    Subject: DZR Quote
Yes, that would be highly recommended. You can start applying gas around 1500 RPM, and then stop the stopwatch at 2000 RPM. For me, it's approximately 7.02 to 7.8 seconds. Yes, it depends on the engine's mood and condition. Passat Variant 205/50-15, 1Z
Post07-12-2002, 12:43    Subject: DZR - Should you wait until 2000, or sooner??? Quote
Hi.
Tim is right because the DZR (Dynamic Resonance Value) is based on the maximum torque curve.
And that level will only be reached when the turbocharger's boost pressure is properly regulated, meaning the initial "turbo lag" phase is already over.
Therefore, apply the accelerator between 1200 and 1500 rpm, and release it between 2000 and 4000 rpm.
No new posts Golf 1J Sounds: Clicking/Popping Noises (Until 09/2000) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L Dashboard - No Display Segments Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AAZ Torque: Low Output, Starts at 3000 RPM Diesel Engine Technology
This topic is locked, you cannot edit or reply. SEO-Optimized: "Best SEO Tools: Free & Paid Options" Diesel Engine Technology
No new posts Full throttle only when the oil is warm? Gasoline Engine Technology
No new posts 14V Charging: Why It Takes 3 Minutes? Transmission, Chassis, Body & Interior
