GRA Not Working Passat 3B 1999
Zimbo30
Post17-08-2006, 20:26    Subject: GRA Not Working Passat 3B 1999 Quote
I have purchased a retrofit kit for my Passat 3B 1.9 TDI, manufactured in March 1999.
"I just installed it, and it's brand new. I've done this before on a Passat 3BG from 2002 without any problems. But today, it didn't work. I was surprised that the light didn't come on when I activated the GRA (automatic high beam). Does the Passat even have a control light for this in the instrument cluster? I activated it with VAG COM, but it's not working. I checked the error memory, but there are no errors. Does anyone have any ideas? I'm 100% sure I connected the cables correctly."
Best regards, Dirk.
Translated on 29-10-2026, 18:09.
Post17-08-2006, 20:53    Subject: GRA Not Working Passat 3B 1999 Quote
Check the switch bits using the diagnostic function and see if GRA (Gearbox Ratio Adaptation) is active (this can be seen in the control unit information in VAG-COM).
Translated on 29-10-2026, 18:10.
R.M.
Karma: +14 / -0   Thank you, like it!
Post17-08-2006, 21:07    Subject: GRA Not Working Passat 3B 1999 Quote
Hello.
My 1998 Passat doesn't have a GRA light in the instrument cluster (GRA was added later), while my father's 2000 Golf does (GRA was original). You can easily see it when the GRA is not active. So, it's likely that your instrument cluster doesn't have a light.
Best regards!
Translated on 29-10-2026, 18:11.
Zimbo30
Post17-08-2006, 22:22    Subject: GRA Not Working Passat 3B 1999 Quote
Thanks for your replies. Are you asking if the GRA (Graphics Rendering Accelerator) is enabled? You can tell if it's enabled by the "G" indicator, but is there a way to check if it's currently active?
Translated on 29-10-2026, 18:12.
Russpartikel
Post17-08-2006, 22:39    Subject: GRA Not Working Passat 3B 1999 Quote
Hi Zimbo30,
As Rainer already mentioned: "Check switch bits via diagnostics."
Rp
P.S. In the diagnosis, it is possible to test the individual "switch functions."
Golf IV Variant MY2000, MKB AGR, Lader, Abgasanlage u. Getriebe EFF vom ARL, MSG Soft ASV+Chip, 0.216 Düsen, Kraftstoffkühler.
mullemaus
Post18-08-2006, 0:55    Subject: GRA Not Working Passat 3B 1999 Quote
Does the Passat even have a control light in the instrument cluster? I've enabled it with VAG COM, but it's not working.
The lamp turns on at a specific software version (year/part number/hardware version of the control unit). If you were to install a control unit from 2002, it would icon_wink.gif
Subject: Vag-Com and GRA, please unlock them again, including turning the ignition on/off to confirm. Then, a test drive. If it still doesn't work, repeat the process. We just had another case where it only worked after the 3rd attempt. The exact reason for this is still unknown icon_wink.gif.
Translated on 29-10-2026, 18:13.
Herr Antje
Post18-08-2006, 5:37    Subject: GRA Not Working Passat 3B 1999 Quote
Zimbo30 wrote:
Does the Passat even have a warning light in the instrument cluster?
Mine is a 01/2001 model.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 29-10-2026, 18:14.
Holger247
Post18-08-2006, 9:52    Subject: GRA Not Working Passat 3B 1999 Quote
Is it just the light that's not working for you, or is the cruise control malfunctioning?
The lamp might not be installed (it wasn't in my Golf IV from 1998 either).
If the cruise control is not working correctly while driving, check the bits using VAG-Com (each switch position can then be read).
I recently had a speed limiter installed (through a VW service action), and the lever was defective (a contact was loose), which could be seen in the VAGCom diagnostic tool. Now I understand why those levers were being offered for sale...
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 29-10-2026, 18:15.
Zimbo30
Post18-08-2006, 20:09    Subject: GRA Not Working Passat 3B 1999 Quote
Nothing is working. Neither the lamp nor the GRA. Where can I read the bits in VAG COM? I've already tried to find something, but without success?
Best regards, Dirk.
Translated on 29-10-2026, 18:16.
BM
Avatar-BM
Post18-08-2006, 22:29    Subject: GRA Not Working Passat 3B 1999 Quote
Not for the 1999 model year.
3B5 AJM
Translated on 29-10-2026, 18:17.
Holger247
Post22-08-2006, 9:21    Subject: GRA Not Working Passat 3B 1999 Quote
Zimbo30:
Where can I read the bits in VAG COM? I've already tried to find something, but without success??
We have a very useful feature in this forum: the search function.
"Cruise control installation problems" "Cruise control" "GRA" "GRA problem" etc.
=> there are many results.
Try using measurement group 6.
GIV - 98 - ALH
Touran 5T 2.0 TDI
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran GRA not working after TCU replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C air conditioning not cooling General Tips
No new posts Air conditioning not working - Passat, 1997 Transmission, Chassis, Body & Interior
No new posts Boost pressure increase for a 1999 Passat TDI with AJM en... Diesel Engine Technology
No new posts Oil Filter for 115 HP PD Engine, Passat 1999 Diesel Engine Technology
No new posts Passat B5 TDI: Engine Misfire at Low Load Diesel Engine Technology
